adding support for Hasselblad raw images (.3fr) in media and previews
    30.0.4
    debian bookworm on Proxmox via helper scripts
How can I help adding previews and general support for raw image files from Hasselblad cameras (.3fr)?
Right now, the files sync nicely, but don’t show up as media files, nor are previews generated. I have installed camera raw previews app in v. 0.8.6, but can’t find a contact (other than here) to write to.
You will need to first find a PHP module that can render those files, and then you will have to simply just add the mimetype. That is the first hurdles though, but not the only ones. You also needs to find a way to extend the preview generator to understand that mimetype and generate a, well, preview.
