mhzr
March 10, 2022, 9:31am
#1
Nextcloud with OnlyOffice installed and works successfully but I can’t add my fonts. I tryed:
sudo -u www-data ./occ documentserver:fonts --add /usr/share/fonts/truetype/farsiweb/IRANYekan.ttf
and then when I try
it shows IRANYekan.ttf but it does’t show IRANYekan font in onlyoffice font menu. Can anyone help me please. Thanks
Maybe this helps? Adding fonts to ONLYOFFICE Docs - ONLYOFFICE
What kind of OnlyOffice-installation do you have? (Embedded, Docker, other)
mhzr
March 10, 2022, 1:25pm
#3
Thank you for recommendation,
I used the following command to install onlyoffice , based on this url:
sudo -u www-data ./occ app:install documentserver_community
sudo -u www-data ./occ app:install onlyoffice
and based on your recommendation I can not find documentserver-generate-allfonts.sh at all. there is no file with similar name in my system . can I download it?
Thanks
