Adding External storage not working, cannot click anything
    • 30.0.6
    • Yunohost 12.0.11 / Debian 12
    • nginx/1.22.1
    • nginx/1.22.1
    • 8.3
    • started happening on my previous install
    • Yunohost
I am not able to setup External storage, because I cannot click or select anything on the UI. The only button that works is the “save” button for the default mounts, which will ask for password, then
  1. say my password was incorrect, even when it’s not
  2. will accept the password on the 2nd try…
  3. but gets stuck forever on “checking password…”
External storage used to work fine on my old install of 30.0.4. After upgrading to 30.0.6, I got lots of different issues. I don’t recall if External Storage stopped working immediately after the upgrade, or after something else - but due to so many issues I could not solve, I reinstalled Yunohost and Nextcloud.
Tested with W10 Firefox, Chrome and Android Firefox, same issue with all of them.
  1. Install Yunohost
  2. Install Nextcloud
PASTE
Summary
        "localhost",
        "***removed***"
    "dbtype": "mysql",
    "version": "30.0.6.2",
    "overwrite.cli.url": "***removed***/nextcloud",
    "dbport": "",
    "mysql.utf8mb4": true,
    "logfile": "\/var\/log\/nextcloud\/nextcloud.log",
    "updatechecker": false,
    "integrity.check.disabled": true,
    "filelocking.enabled": true,
    "redis": {
        "port": "6379",
        "timeout": "0.0",
    "hashing_default_password": true,
    "localstorage.allowsymlinks": true,
    "default_phone_region": "FI",
    "mail_smtpmode": "smtp",
    "mail_smtpport": "25",
    "mail_smtpauth": 1,
    "mail_sendmailmode": "smtp",
    "mail_smtpstreamoptions": {
        "ssl": {
            "allow_self_signed": true,
            "verify_peer": false,
            "verify_peer_name": false
    "logout_url": "***removed***?action=logout&r=aHR0cHM6Ly9jYXRyaWsubm9oby5zdC9uZXh0Y2xvdWQ=",
    "maintenance": false
Summary
  • activity: 3.0.0
  • app_api: 4.0.6
  • bruteforcesettings: 3.0.0
  • circles: 30.0.0
  • cloud_federation_api: 1.13.0
  • comments: 1.20.1
  • contactsinteraction: 1.11.0
  • dashboard: 7.10.0
  • dav: 1.31.1
  • federatedfilesharing: 1.20.0
  • federation: 1.20.0
  • files: 2.2.0
  • files_downloadlimit: 3.0.0
  • files_external: 1.22.0
  • files_pdfviewer: 3.0.0
  • files_reminders: 1.3.0
  • files_sharing: 1.22.0
  • files_trashbin: 1.20.1
  • files_versions: 1.23.0
  • firstrunwizard: 3.0.0
  • logreader: 3.0.0
  • lookup_server_connector: 1.18.0
  • nextcloud_announcements: 2.0.0
  • notifications: 3.0.0
  • oauth2: 1.18.1
  • password_policy: 2.0.0
  • photos: 3.0.2
  • privacy: 2.0.0
  • provisioning_api: 1.20.0
  • recommendations: 3.0.0
  • related_resources: 1.5.0
  • serverinfo: 2.0.0
  • settings: 1.13.0
  • sharebymail: 1.20.0
  • support: 2.0.0
  • survey_client: 2.0.0
  • systemtags: 1.20.0
  • text: 4.1.0
  • theming: 2.6.0
  • twofactor_backupcodes: 1.19.0
  • user_ldap: 1.21.0
  • user_status: 1.10.0
  • viewer: 3.0.0
  • weather_status: 1.10.0
  • webhook_listeners: 1.1.0-dev
  • workflowengine: 2.12.0
  • admin_audit: 1.20.0
  • encryption: 2.18.0
  • suspicious_login: 8.0.0
  • twofactor_nextcloud_notification: 4.0.0
  • twofactor_totp: 12.0.0-dev
  • updatenotification: 1.20.0 (installed 1.20.0)
I tried to add external storage via SSH, but I did not find any documentation on how to do it properly and I could not get it to working.
Here’s what I did
  1. files_external:export
  2. Made a .json file out of the export
  3. changed mount_id, mount_point and datadir. I did not know what to put in storage, so I left it as is.
  4. Imported the .json
The new storage will be shown with files_external:list, Mount ID 5 in the screenshot, and it will be visible in the web ui, but you cant access it. It just says “storage temporarily unavailable”.
