Nextcloud version (eg, 12.0.2): 16.0.4
Operating system and version (eg, Ubuntu 17.04): debian 9
Apache or nginx version (eg, Apache 2.4.25): nginx 1.14.2
PHP version (eg, 7.1): 7.2
After upgrade to nc 16.0.4 from 16.0.3 i cant seem to add files into projects anymore.
Is this the first time you’ve seen this error? (Y/N): Yes
Does anyone else have the same problem? From what i can see it happend on the upgrade to 16.0.4 as i can see it on many other servers where i have not done the upgrade yet.
I am going to dig a bit deeper and check the logs and see if its something i can find.
additionalScripts.js?v=ceac8164-17:1 Uncaught (in promise) TypeError: Cannot read property ‘call’ of undefined
at r (additionalScripts.js?v=ceac8164-17:1)
at Module.14 (files_sharing.4.js:1)
found that that is not showing on the other installations
I haven’t tested this feature before, so had my first attempt on NC16.0.4 now, but it worked.
Twice I linked a file with another file and added a third file to that project.
