ReDLeX
October 21, 2023, 1:30pm
1
Nextcloud version (eg, 20.0.5) : Nextcloud-AIO:Latest
Operating system and version (eg, Ubuntu 20.04) : RaspbianOS 64bit Bullseye Legacy
Apache or nginx version (eg, Apache 2.4.25) : Apache:Latest
PHP version (eg, 7.4) : Don't know
I have setup a Nextcloud-AIO server using a Cloudflare tunnel on RaspbianOS and Openmediavault 6. Everything is working fine. I have to use a Cloudflare tunnel as my ISP blocks port-forwarding.
I would now like to add an external drive, which is available on the Openmediavault server. Openmediavault is running locally and Nextcloud-AIO is running in a docker container.
The IP address of the Raspberry is 192.168.1.7 and SMB is enabled.
The domain for the Cloudflare tunnel is called “Nextcloud.K…com”
The drive has absolute path: /srv/dev-disk-by-uuid-d76ef5f1-0a1a-4e4c-875f/Data
Can someone help me mount the drive to Nextcloud?
Many thanks in advance.
ReDLeX
October 21, 2023, 1:56pm
3
Yes, correct.
Thanks, will have a look right away.
ReDLeX
October 21, 2023, 2:50pm
4
I added the environment “- NEXTCLOUD_MOUNT=”/srv/dev-disk-by-uuid-d76ef5f1-0a1a-4e4c-875f/Data" to my docker-compose.yml
services:
restart: always
volumes:
ports:
- 8080:8080
environment:
- APACHE_PORT=11000
- NEXTCLOUD_DATADIR=/Nextcloud
- SKIP_DOMAIN_VALIDATION=true
- NEXTCLOUD_MOUNT="/srv/dev-disk-by-uuid-d76ef5f1-0a1a-4e4c-875f/Data"
volumes:
If I understand correctly, now I need to mount it locally, but the option for local is not there.
Amazon S3
FTP
Openstack Object Storage
SFTP
SMB/CIFS
WebDAV
Are the only options.
Any idea how to get local to appear?
Restart the containers from the aio interface
ReDLeX
October 21, 2023, 3:16pm
6
I can’t seem to open 192.168.1.7:8080.
When I check to logs for the Nextcloud-AIO it gives: ERROR: Wrong IP address ‘’ in listen.allowed_clients
Not had this before, happened after restarting the containers. Still using the same code from my initial post.
I can reach nextcloud.k…com and Nextcloud is displayed.
Hm… Can you switch to the beta channel and check if that resolves this?
ReDLeX
October 21, 2023, 3:20pm
8
How do I change to that channel?
ReDLeX
October 21, 2023, 3:33pm
10
I think I found the issue, or at least one of the issues.
I added the next to environment
Should have been:
- NEXTCLOUD_MOUNT=/srv/dev-disk-by-uuid-d76ef5f1-0a1a-4e4c-875f/Data
Now I’m able to restart the nextcloud-aio container and am able to reach the https://192.168.1.7:8080/containers page.
I just hit the stop all containers button and restarted them.
ReDLeX
October 21, 2023, 5:54pm
11
Restarting all the containers made local visable in “external storage”. Now I was able to mount the OMV drive.
ReDLeX
October 21, 2023, 5:56pm
12
Final code used
services:
restart: always
volumes:
ports:
- 8080:8080
environment:
- APACHE_PORT=11000
volumes:
