I shared files for everyone who has the link.
Now i want to use some of this files for a bash script.
Is there any possiblity to access the files via davfs?
Thank you
Thank you
I might be wrong but if you’ve shared a file with everyone and without the need to have a valid Nextcloud account, the file can be downloaded using standard https. A WebDAV share is normally only used to access files if you have a valid Nextcloud account.
just:
curl https://domain/index.php/s/SHARE_ID/download?path=/?files=fileName.exe
if file under subfolder of shared folder then:
curl https://domain/index.php/s/SHARE_ID/download?path=/Some/Sub/Folder?files=fileName.exe
Thanks for the help.
It would be easier if i could use directorys, but it would work with downloads, too.
I want to download whole folders. I have to download them as compressed and then uncompress, or?
If you use
you will download compressed directory, but you can always download file by file
To find files you can use curl -X PROPFIND to the /public.php/webdav/. It was mentioned here Uploading a file to File Drop using http post method, but I do not know how it works, I only can see that request is done via Browser, when I trying to do this via curl - not succeed.
I use the directory to store configuration files of programs for a Ubuntu 20.04 installation.
It would be great if i didn’t have to install a new programm for this.
I didn’t find the right url to download a whole directory with wget.
Did the “downloadStartSecret” change?
Personally I use git for same purpose, for me it looks more feasible also with clear versioning of configs and branches if needed. I run Gitea as service near to NC and quite impressed with performance of it.
I did not check that.
