### ⚠️ This issue respects the following points: ⚠️
- [X] This is a **bug**, …not a question or a configuration/webserver/proxy issue.
- [X] This issue is **not** already reported on [Github](https://github.com/nextcloud/server/issues?q=is%3Aopen+is%3Aissue+label%3Abug) OR [Nextcloud Community Forum](https://help.nextcloud.com/) _(I've searched it)_.
- [X] Nextcloud Server **is** up to date. See [Maintenance and Release Schedule](https://github.com/nextcloud/server/wiki/Maintenance-and-Release-Schedule) for supported versions.
- [X] I agree to follow Nextcloud's [Code of Conduct](https://nextcloud.com/contribute/code-of-conduct/).
### Bug description
On every backgroundjob I see an error at protocol:
DriverException
An exception occurred while executing a query: SQLSTATE[42803]: Grouping error: 7 ERROR: column "cr.id" must appear in the GROUP BY clause or be used in an aggregate function LINE 1: SELECT "cr".*, "co"."calendardata", "c"."displayname", "c"."... ^
Error while running background job OCA\DAV\BackgroundJob\EventReminderJob (id: 9156, arguments: null)
### Steps to reproduce
1. Use NC30 RC1
2. Let CRON start backgroundjobs
3. Look at your logfile.
### Expected behavior
No error should be visible.
### Installation method
None
### Nextcloud Server version
30rc1
### Operating system
Ubuntu 22.04
### PHP engine version
8.2
### Web server
Apache
### Database engine version
PostgreSQL
### Is this bug present after an update or on a fresh install?
None
### Are you using the Nextcloud Server Encryption module?
None
### What user-backends are you using?
- [x] Default user-backend _(database)_
- [x] LDAP/ Active Directory
- [ ] SSO - SAML
- [ ] Other
### Configuration report
```shell
"debug": false,
"cloud.s-t-franz.de",
"localhost",
"192.168.1.3",
"nextcloud"
"overwrite.cli.url": "https:\/\/192.168.1.3\/nextcloud",
"overwritehost": "cloud.s-t-franz.de",
"dbtype": "pgsql",
"version": "30.0.0.8",
"dbport": "",
"session_relaxed_expiry": false,
"mail_smtpmode": "smtp",
"log_rotate_size": "10485760",
"maintenance_window_start": "1",
"filelocking.enabled": true,
"redis": {
"port": 0,
"timeout": 0.5,
"dbindex": 0,
"htaccess.RewriteBase": "\/",
"loglevel": "2",
"log_type": "file",
"logfile": "\/mnt\/ncdata\/nextcloud.log",
"logtimezone": "Europe\/Berlin",
"default_phone_region": "DE",
"ldapIgnoreNamingRules": false,
"ldapProviderFactory": "\\OCA\\User_LDAP\\LDAPProviderFactory",
"mail_smtpauthtype": "LOGIN",
"mail_smtpport": "25",
"mail_smtpstreamoptions": {
"ssl": {
"allow_self_signed": true,
"verify_peer": false,
"verify_peer_name": false
"theme": "",
"updater.release.channel": "beta",
"app_install_overwrite": [
"calendar",
"bruteforcesettings",
"admin_notifications",
"onlyoffice",
"files_trackdownloads",
"checksum",
"music",
"twofactor_totp",
"twofactor_email",
"impersonate",
"previewgenerator"
"twofactor_enforced": "true",
"twofactor_enforced_groups": [],
"has_rebuilt_cache": true,
"mail_sendmailmode": "smtp"
### List of activated Apps
```shell
- activity: 3.0.0
- admin_audit: 1.20.0
- admin_notifications: 1.0.2
- bruteforcesettings: 3.0.0
- checksum: 1.2.4
- comments: 1.20.1
- contactsinteraction: 1.11.0
- dav: 1.31.1
- federation: 1.20.0
- files: 2.2.0
- files_downloadlimit: 3.0.0
- files_pdfviewer: 3.0.0
- files_reminders: 1.3.0
- files_sharing: 1.22.0
- files_trashbin: 1.20.1
- files_versions: 1.23.0
- firstrunwizard: 3.0.0
- impersonate: 1.17.0
- integration_openai: 3.0.1
- logreader: 3.0.0
- notifications: 3.0.0
- oauth2: 1.18.0
- password_policy: 2.0.0
- photos: 3.0.2
- privacy: 2.0.0
- provisioning_api: 1.20.0
- recommendations: 3.0.0
- related_resources: 1.5.0
- serverinfo: 2.0.0
- settings: 1.13.0
- sharebymail: 1.20.0
- support: 2.0.0
- survey_client: 2.0.0
- systemtags: 1.20.0
- theming: 2.5.0
- twofactor_email: 2.7.4
- twofactor_totp: 12.0.0-dev
- updatenotification: 1.20.0
- user_ldap: 1.21.0
- user_status: 1.10.0
- viewer: 3.0.0
- workflowengine: 2.12.0
- circles: 30.0.0-dev (installed 28.0.0-dev)
- dashboard: 7.10.0 (installed 7.1.0)
- encryption: 2.18.0
- files_external: 1.22.0
- suspicious_login: 8.0.0
- text: 4.1.0 (installed 3.9.1)
- weather_status: 1.10.0 (installed 1.0.0)
### Nextcloud Signing status
```shell
No errors have been found.
### Nextcloud Logs
```shell
{"reqId":"6jbk5hTxCTGD3EtOmsWM","level":3,"time":"2024-08-16T12:15:08+02:00","remoteAddr":"","user":"--","app":"core","method":"","url":"--","message":"Error while running background job OCA\\DAV\\BackgroundJob\\EventReminderJob (id: 9156, arguments: null)","userAgent":"--","version":"30.0.0.8","exception":{"Exception":"Doctrine\\DBAL\\Exception\\DriverException","Message":"An exception occurred while executing a query: SQLSTATE[42803]: Grouping error: 7 ERROR: column \"cr.id\" must appear in the GROUP BY clause or be used in an aggregate function\nLINE 1: SELECT \"cr\".*, \"co\".\"calendardata\", \"c\".\"displayname\", \"c\".\"...\n ^","Code":7,"Trace":[{"file":"/var/www/nextcloud/3rdparty/doctrine/dbal/src/Connection.php","line":1943,"function":"convert","class":"Doctrine\\DBAL\\Driver\\API\\PostgreSQL\\ExceptionConverter","type":"->"},{"file":"/var/www/nextcloud/3rdparty/doctrine/dbal/src/Connection.php","line":1885,"function":"handleDriverException","class":"Doctrine\\DBAL\\Connection","type":"->"},{"file":"/var/www/nextcloud/3rdparty/doctrine/dbal/src/Connection.php","line":1106,"function":"convertExceptionDuringQuery","class":"Doctrine\\DBAL\\Connection","type":"->"},{"file":"/var/www/nextcloud/lib/private/DB/Connection.php","line":312,"function":"executeQuery","class":"Doctrine\\DBAL\\Connection","type":"->"},{"file":"/var/www/nextcloud/lib/private/DB/ConnectionAdapter.php","line":48,"function":"executeQuery","class":"OC\\DB\\Connection","type":"->"},{"file":"/var/www/nextcloud/lib/private/DB/QueryBuilder/QueryBuilder.php","line":271,"function":"executeQuery","class":"OC\\DB\\ConnectionAdapter","type":"->"},{"file":"/var/www/nextcloud/lib/private/DB/QueryBuilder/QueryBuilder.php","line":248,"function":"executeQuery","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/CalDAV/Reminder/Backend.php","line":53,"function":"execute","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/CalDAV/Reminder/ReminderService.php","line":104,"function":"getRemindersToProcess","class":"OCA\\DAV\\CalDAV\\Reminder\\Backend","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/BackgroundJob/EventReminderJob.php","line":50,"function":"processReminders","class":"OCA\\DAV\\CalDAV\\Reminder\\ReminderService","type":"->"},{"file":"/var/www/nextcloud/lib/public/BackgroundJob/Job.php","line":61,"function":"run","class":"OCA\\DAV\\BackgroundJob\\EventReminderJob","type":"->"},{"file":"/var/www/nextcloud/lib/public/BackgroundJob/TimedJob.php","line":83,"function":"start","class":"OCP\\BackgroundJob\\Job","type":"->"},{"file":"/var/www/nextcloud/lib/public/BackgroundJob/TimedJob.php","line":73,"function":"start","class":"OCP\\BackgroundJob\\TimedJob","type":"->"},{"file":"/var/www/nextcloud/cron.php","line":162,"function":"execute","class":"OCP\\BackgroundJob\\TimedJob","type":"->"}],"File":"/var/www/nextcloud/3rdparty/doctrine/dbal/src/Driver/API/PostgreSQL/ExceptionConverter.php","Line":87,"Previous":{"Exception":"Doctrine\\DBAL\\Driver\\PDO\\Exception","Message":"SQLSTATE[42803]: Grouping error: 7 ERROR: column \"cr.id\" must appear in the GROUP BY clause or be used in an aggregate function\nLINE 1: SELECT \"cr\".*, \"co\".\"calendardata\", \"c\".\"displayname\", \"c\".\"...\n ^","Code":7,"Trace":[{"file":"/var/www/nextcloud/3rdparty/doctrine/dbal/src/Driver/PDO/Statement.php","line":132,"function":"new","class":"Doctrine\\DBAL\\Driver\\PDO\\Exception","type":"::"},{"file":"/var/www/nextcloud/3rdparty/doctrine/dbal/src/Connection.php","line":1099,"function":"execute","class":"Doctrine\\DBAL\\Driver\\PDO\\Statement","type":"->"},{"file":"/var/www/nextcloud/lib/private/DB/Connection.php","line":312,"function":"executeQuery","class":"Doctrine\\DBAL\\Connection","type":"->"},{"file":"/var/www/nextcloud/lib/private/DB/ConnectionAdapter.php","line":48,"function":"executeQuery","class":"OC\\DB\\Connection","type":"->"},{"file":"/var/www/nextcloud/lib/private/DB/QueryBuilder/QueryBuilder.php","line":271,"function":"executeQuery","class":"OC\\DB\\ConnectionAdapter","type":"->"},{"file":"/var/www/nextcloud/lib/private/DB/QueryBuilder/QueryBuilder.php","line":248,"function":"executeQuery","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/CalDAV/Reminder/Backend.php","line":53,"function":"execute","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/CalDAV/Reminder/ReminderService.php","line":104,"function":"getRemindersToProcess","class":"OCA\\DAV\\CalDAV\\Reminder\\Backend","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/BackgroundJob/EventReminderJob.php","line":50,"function":"processReminders","class":"OCA\\DAV\\CalDAV\\Reminder\\ReminderService","type":"->"},{"file":"/var/www/nextcloud/lib/public/BackgroundJob/Job.php","line":61,"function":"run","class":"OCA\\DAV\\BackgroundJob\\EventReminderJob","type":"->"},{"file":"/var/www/nextcloud/lib/public/BackgroundJob/TimedJob.php","line":83,"function":"start","class":"OCP\\BackgroundJob\\Job","type":"->"},{"file":"/var/www/nextcloud/lib/public/BackgroundJob/TimedJob.php","line":73,"function":"start","class":"OCP\\BackgroundJob\\TimedJob","type":"->"},{"file":"/var/www/nextcloud/cron.php","line":162,"function":"execute","class":"OCP\\BackgroundJob\\TimedJob","type":"->"}],"File":"/var/www/nextcloud/3rdparty/doctrine/dbal/src/Driver/PDO/Exception.php","Line":28,"Previous":{"Exception":"PDOException","Message":"SQLSTATE[42803]: Grouping error: 7 ERROR: column \"cr.id\" must appear in the GROUP BY clause or be used in an aggregate function\nLINE 1: SELECT \"cr\".*, \"co\".\"calendardata\", \"c\".\"displayname\", \"c\".\"...\n ^","Code":"42803","Trace":[{"file":"/var/www/nextcloud/3rdparty/doctrine/dbal/src/Driver/PDO/Statement.php","line":130,"function":"execute","class":"PDOStatement","type":"->"},{"file":"/var/www/nextcloud/3rdparty/doctrine/dbal/src/Connection.php","line":1099,"function":"execute","class":"Doctrine\\DBAL\\Driver\\PDO\\Statement","type":"->"},{"file":"/var/www/nextcloud/lib/private/DB/Connection.php","line":312,"function":"executeQuery","class":"Doctrine\\DBAL\\Connection","type":"->"},{"file":"/var/www/nextcloud/lib/private/DB/ConnectionAdapter.php","line":48,"function":"executeQuery","class":"OC\\DB\\Connection","type":"->"},{"file":"/var/www/nextcloud/lib/private/DB/QueryBuilder/QueryBuilder.php","line":271,"function":"executeQuery","class":"OC\\DB\\ConnectionAdapter","type":"->"},{"file":"/var/www/nextcloud/lib/private/DB/QueryBuilder/QueryBuilder.php","line":248,"function":"executeQuery","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/CalDAV/Reminder/Backend.php","line":53,"function":"execute","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/CalDAV/Reminder/ReminderService.php","line":104,"function":"getRemindersToProcess","class":"OCA\\DAV\\CalDAV\\Reminder\\Backend","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/BackgroundJob/EventReminderJob.php","line":50,"function":"processReminders","class":"OCA\\DAV\\CalDAV\\Reminder\\ReminderService","type":"->"},{"file":"/var/www/nextcloud/lib/public/BackgroundJob/Job.php","line":61,"function":"run","class":"OCA\\DAV\\BackgroundJob\\EventReminderJob","type":"->"},{"file":"/var/www/nextcloud/lib/public/BackgroundJob/TimedJob.php","line":83,"function":"start","class":"OCP\\BackgroundJob\\Job","type":"->"},{"file":"/var/www/nextcloud/lib/public/BackgroundJob/TimedJob.php","line":73,"function":"start","class":"OCP\\BackgroundJob\\TimedJob","type":"->"},{"file":"/var/www/nextcloud/cron.php","line":162,"function":"execute","class":"OCP\\BackgroundJob\\TimedJob","type":"->"}],"File":"/var/www/nextcloud/3rdparty/doctrine/dbal/src/Driver/PDO/Statement.php","Line":130}},"message":"Error while running background job OCA\\DAV\\BackgroundJob\\EventReminderJob (id: 9156, arguments: null)","exception":{},"CustomMessage":"Error while running background job OCA\\DAV\\BackgroundJob\\EventReminderJob (id: 9156, arguments: null)"}}
### Additional info
_No response_
