I need to use file share and Calendar features in my organization, which product is meet me requests?
And what’s the difference between Nextcloud and AIO?
Thank you so much.
Thank you so much.
@flyfish712
I think you can use Nextcloud. You can create a 60 minutes test account at https://try.nextcloud.com. The password is demo
. Server is https://demo1.nextcloud.com
or https://demo2.nextcloud.com
. Also you can find free nextcloud provider to test “file share” and “Calendar”.
AIO (Nextcloud All-in-One) is a special form for Nextcloud installation:
See Install - Nextcloud
Read also GitHub - nextcloud/all-in-one: Nextcloud AIO stands for Nextcloud All In One and provides easy deployment and maintenance with most features included in this one Nextcloud instance.
AIO is a Nextcloud docker image.
Not completely correct. See GitHub - nextcloud/all-in-one: Nextcloud AIO stands for Nextcloud All In One and provides easy deployment and maintenance with most features included in this one Nextcloud instance.
Thank you guys detailed answer, I will read the documents arefully.
