502 Bad Gateway from Nginx Reverse Proxy with Nextcloud AIO
Unused or stopped? I ran these commands after stopping all but the mastercontainer via the AIO portal:
docker ps -a --filter "status=exited"
docker rm $(docker ps -aq --filter "status=exited")
Not sure if there is something else you are talking about though. Given the reference page for docker, I believe the docker container prune command and what I did (more manual) accomplish the same thing.
When I restarted AIO (after compose down/up), it did prompt me to download updated images.
Unfortunately, recreating all the containers did NOT fix the issue. The was a crash again early this morning. At this point, it does not look memory related and is persisting beyond the container rebuilds. I did grab logs again and can post those if needed.
If anyone has any other suggestions or requests, I am open to anything at this point. Thank you.
root@vps:~# free -h
               total        used        free      shared  buff/cache   available
Mem:            15Gi       2.7Gi       268Mi       257Mi        13Gi        12Gi
Swap:          511Mi       511Mi       196Ki
root@vps:~# docker stats --no-stream --format "$(date): {{.Name}} {{.MemUsage}}"
Mon Apr 27 10:08:18 EDT 2026: nextcloud-aio-nextcloud 3.203MiB / 15.52GiB
Mon Apr 27 10:08:18 EDT 2026: nextcloud-aio-imaginary 9.914MiB / 15.52GiB
Mon Apr 27 10:08:18 EDT 2026: nextcloud-aio-redis 4.965MiB / 15.52GiB
Mon Apr 27 10:08:18 EDT 2026: nextcloud-aio-database 184.9MiB / 15.52GiB
Mon Apr 27 10:08:18 EDT 2026: nextcloud-aio-notify-push 1.32MiB / 15.52GiB
Mon Apr 27 10:08:18 EDT 2026: nextcloud-aio-collabora 57.89MiB / 15.52GiB
Mon Apr 27 10:08:18 EDT 2026: nextcloud-aio-mastercontainer 68.21MiB / 15.52GiB
Hi, we are trying to improve the php config in Fix intermittent 502 Bad Gateway: PHP-FPM request_terminate_timeout + process_idle_timeout by Copilot · Pull Request #8013 · nextcloud/all-in-one · GitHub in the next release to try to prevent such problems from happening.
This is now released with v13.0.0 Beta. Testing and feedback is welcome! See GitHub - nextcloud/all-in-one: 📦 The official Nextcloud installation method. Provides easy deployment and maintenance with most features included in this one Nextcloud instance. · GitHub
Thank you. I will install it and try it.
Unfortunately, that still did not work. I had a crash again this morning. Same thing with the 502 Bad Gateway.
root@vps:~# docker ps -a
CONTAINER ID   IMAGE                                             COMMAND                  CREATED       STATUS                    PORTS                                                NAMES
c9bb1b3df454   ghcr.io/nextcloud-releases/aio-apache:beta        "/start.sh /usr/bin/…"   5 hours ago   Created        nextcloud-aio-apache
f8c9bfea7d09   ghcr.io/nextcloud-releases/aio-nextcloud:beta     "/start.sh /usr/bin/…"   5 hours ago   Up 5 hours (unhealthy)    9000/tcp                                             nextcloud-aio-nextcloud
3f297cf0707a   ghcr.io/nextcloud-releases/aio-imaginary:beta     "/start.sh"              5 hours ago   Up 5 hours (healthy)                                                           nextcloud-aio-imaginary
86d33b4d9d1b   ghcr.io/nextcloud-releases/aio-redis:beta         "/start.sh"              5 hours ago   Up 5 hours (healthy)      6379/tcp                                             nextcloud-aio-redis
39eda8378a73   ghcr.io/nextcloud-releases/aio-postgresql:beta    "/start.sh"              5 hours ago   Up 5 hours (healthy)      5432/tcp                                             nextcloud-aio-database
842251471d5a   ghcr.io/nextcloud-releases/aio-notify-push:beta   "/start.sh"              5 hours ago   Up 5 hours (healthy)                                                           nextcloud-aio-notify-push
31099e7ebebf   ghcr.io/nextcloud-releases/aio-collabora:beta     "/start.sh"              5 hours ago   Up 13 minutes (healthy)   9980/tcp                                             nextcloud-aio-collabora
997807c7cc7a   ghcr.io/nextcloud-releases/aio-borgbackup:beta    "/start.sh"              5 hours ago   Exited (0) 5 hours ago                                                         nextcloud-aio-borgbackup
3ab137b71d6d   ghcr.io/nextcloud-releases/aio-watchtower:beta    "/start.sh"              5 hours ago   Exited (0) 5 hours ago                                                         nextcloud-aio-watchtower
dce6539aebf9   ghcr.io/nextcloud-releases/all-in-one:beta        "/start.sh"              3 days ago    Up 3 days (healthy)       80/tcp, 8443/tcp, 9000/tcp, 0.0.0.0:8080->8080/tcp   nextcloud-aio-mastercontainer
root@vps:~# free -h
Mem:            15Gi       2.3Gi       341Mi       277Mi        13Gi        13Gi
Swap:          511Mi       511Mi       644Ki
Mon May 11 10:25:19 EDT 2026: nextcloud-aio-nextcloud 3.93MiB / 15.52GiB
Mon May 11 10:25:19 EDT 2026: nextcloud-aio-imaginary 9.66MiB / 15.52GiB
Mon May 11 10:25:19 EDT 2026: nextcloud-aio-redis 7.27MiB / 15.52GiB
Mon May 11 10:25:19 EDT 2026: nextcloud-aio-database 209MiB / 15.52GiB
Mon May 11 10:25:19 EDT 2026: nextcloud-aio-notify-push 1.145MiB / 15.52GiB
Mon May 11 10:25:19 EDT 2026: nextcloud-aio-collabora 58.07MiB / 15.52GiB
Mon May 11 10:25:19 EDT 2026: nextcloud-aio-mastercontainer 58.18MiB / 15.52GiB
One thing I have noticed is that the aio-collabora container is always restarting it seems. These are all from the past 3 days (1 per day). I have never seen the aio-collabora container be up longer than 14 minutes. I assume this is intended as part of the fix in the 13.0.x version. If not, then it might be a symptom of the larger crash issue.
I have not had a crash since the last time I posted 5 days ago.
root@vps:/etc# docker ps -a
dcbea79e465f   ghcr.io/nextcloud-releases/aio-apache:beta        "/start.sh /usr/bin/…"   10 hours ago   Up 10 hours (healthy)     80/tcp, 0.0.0.0:11000->11000/tcp                     nextcloud-aio-apache
dfa2ee428b1b   ghcr.io/nextcloud-releases/aio-nextcloud:beta     "/start.sh /usr/bin/…"   10 hours ago   Up 10 hours (healthy)     9000/tcp                                             nextcloud-aio-nextcloud
6d49c39cb553   ghcr.io/nextcloud-releases/aio-imaginary:beta     "/start.sh"              10 hours ago   Up 10 hours (healthy)                                                          nextcloud-aio-imaginary
7b441caa9bae   ghcr.io/nextcloud-releases/aio-redis:beta         "/start.sh"              10 hours ago   Up 10 hours (healthy)     6379/tcp                                             nextcloud-aio-redis
17b2f446aea7   ghcr.io/nextcloud-releases/aio-postgresql:beta    "/start.sh"              10 hours ago   Up 10 hours (healthy)     5432/tcp                                             nextcloud-aio-database
715172a8bf2d   ghcr.io/nextcloud-releases/aio-notify-push:beta   "/start.sh"              10 hours ago   Up 10 hours (healthy)                                                          nextcloud-aio-notify-push
0bf365a0e813   ghcr.io/nextcloud-releases/aio-collabora:beta     "/start.sh"              10 hours ago   Up 2 minutes (healthy)    9980/tcp                                             nextcloud-aio-collabora
3655433d2400   ghcr.io/nextcloud-releases/aio-borgbackup:beta    "/start.sh"              10 hours ago   Exited (0) 10 hours ago                                                        nextcloud-aio-borgbackup
c547c4dd4c6a   ghcr.io/nextcloud-releases/aio-watchtower:beta    "/start.sh"              10 hours ago   Exited (0) 10 hours ago                                                        nextcloud-aio-watchtower
dce6539aebf9   ghcr.io/nextcloud-releases/all-in-one:beta        "/start.sh"              6 days ago     Up 3 days (healthy)       80/tcp, 8443/tcp, 9000/tcp, 0.0.0.0:8080->8080/tcp   nextcloud-aio-mastercontainer
9f8a554a074c   ghcr.io/nextcloud-releases/aio-apache:beta        "/start.sh /usr/bin/…"   7 hours ago   Up 7 hours (healthy)     80/tcp, 0.0.0.0:11000->11000/tcp                     nextcloud-aio-apache
774380923a5f   ghcr.io/nextcloud-releases/aio-nextcloud:beta     "/start.sh /usr/bin/…"   7 hours ago   Up 7 hours (healthy)     9000/tcp                                             nextcloud-aio-nextcloud
647b5998985e   ghcr.io/nextcloud-releases/aio-imaginary:beta     "/start.sh"              7 hours ago   Up 7 hours (healthy)                                                          nextcloud-aio-imaginary
5327d484b25f   ghcr.io/nextcloud-releases/aio-redis:beta         "/start.sh"              7 hours ago   Up 7 hours (healthy)     6379/tcp                                             nextcloud-aio-redis
cf28c4107116   ghcr.io/nextcloud-releases/aio-postgresql:beta    "/start.sh"              7 hours ago   Up 7 hours (healthy)     5432/tcp                                             nextcloud-aio-database
d3b7991765c7   ghcr.io/nextcloud-releases/aio-notify-push:beta   "/start.sh"              7 hours ago   Up 7 hours (healthy)                                                          nextcloud-aio-notify-push
8fca57061507   ghcr.io/nextcloud-releases/aio-collabora:beta     "/start.sh"              7 hours ago   Up 3 minutes (healthy)   9980/tcp                                             nextcloud-aio-collabora
5cd3f774d2d8   ghcr.io/nextcloud-releases/aio-borgbackup:beta    "/start.sh"              7 hours ago   Exited (0) 7 hours ago                                                        nextcloud-aio-borgbackup
44ad7ae5d8cf   ghcr.io/nextcloud-releases/aio-watchtower:beta    "/start.sh"              7 hours ago   Exited (0) 7 hours ago                                                        nextcloud-aio-watchtower
dce6539aebf9   ghcr.io/nextcloud-releases/all-in-one:beta        "/start.sh"              7 days ago    Up 4 days (healthy)      80/tcp, 8443/tcp, 9000/tcp, 0.0.0.0:8080->8080/tcp   nextcloud-aio-mastercontainer
e31dc69be239   ghcr.io/nextcloud-releases/aio-apache:beta        "/start.sh /usr/bin/…"   3 hours ago   Up 3 hours (healthy)      80/tcp, 0.0.0.0:11000->11000/tcp                     nextcloud-aio-apache
867788b1dd45   ghcr.io/nextcloud-releases/aio-nextcloud:beta     "/start.sh /usr/bin/…"   3 hours ago   Up 3 hours (healthy)      9000/tcp                                             nextcloud-aio-nextcloud
66b18d15b65a   ghcr.io/nextcloud-releases/aio-imaginary:beta     "/start.sh"              3 hours ago   Up 3 hours (healthy)                                                           nextcloud-aio-imaginary
4ca28b0af465   ghcr.io/nextcloud-releases/aio-redis:beta         "/start.sh"              3 hours ago   Up 3 hours (healthy)      6379/tcp                                             nextcloud-aio-redis
068c4f8c7315   ghcr.io/nextcloud-releases/aio-postgresql:beta    "/start.sh"              3 hours ago   Up 3 hours (healthy)      5432/tcp                                             nextcloud-aio-database
c0506fe5b69b   ghcr.io/nextcloud-releases/aio-notify-push:beta   "/start.sh"              3 hours ago   Up 3 hours (healthy)                                                           nextcloud-aio-notify-push
80bbd3a0d53b   ghcr.io/nextcloud-releases/aio-collabora:beta     "/start.sh"              3 hours ago   Up 14 minutes (healthy)   9980/tcp                                             nextcloud-aio-collabora
c283ccc50fc1   ghcr.io/nextcloud-releases/aio-borgbackup:beta    "/start.sh"              3 hours ago   Exited (0) 3 hours ago                                                         nextcloud-aio-borgbackup
5d2fa20a1ea2   ghcr.io/nextcloud-releases/aio-watchtower:beta    "/start.sh"              3 hours ago   Exited (0) 3 hours ago                                                         nextcloud-aio-watchtower
1e57110fd422   ghcr.io/nextcloud-releases/all-in-one:beta        "/start.sh"              3 hours ago   Up 3 hours (healthy)      80/tcp, 8443/tcp, 9000/tcp, 0.0.0.0:8080->8080/tcp   nextcloud-aio-mastercontainer
Ok, in the time since my last post, we decided to spin up a new server. Same exact configuration on CPU, RAM, Drives, and model. Moved the necessary docker volumes and compose file over and spun it all up. So far, no crashes since doing that. Additionally the nextcloud-aio-collabora container is behaving.
Assuming this good behavior continues, I will close out the thread in a few days and consider it resolved by two things:
  • v13.0.x of NextCloud AIO
  • New OS/docker installation
Unfortunately, I am still having “crashes” and 502 Bad Gateway errors. Even after moving to a new server and starting with fresh images. It does seem to be a slightly different crash though than before. It has now happened twice. I have logs somewhere, but am traveling at the moment so may not get to post them until later.
The nextcloud-aio-apache container is in a Created state, but not started. Just curious if anyone else has seen this Created status?
Here is what I see in docker ps:
df3a42f1b6ab   ghcr.io/nextcloud-releases/aio-apache:latest        "/start.sh /usr/bin/…"   5 hours ago   Created                                 nextcloud-aio-apache
6779ac75f250   ghcr.io/nextcloud-releases/aio-nextcloud:latest     "/start.sh /usr/bin/…"   5 hours ago   Exited (137) 2 minutes ago   9000/tcp   nextcloud-aio-nextcloud
c7a9e99f2467   ghcr.io/nextcloud-releases/aio-imaginary:latest     "/start.sh"              5 hours ago   Exited (0) 8 seconds ago                nextcloud-aio-imaginary
b7c3b0b5c02a   ghcr.io/nextcloud-releases/aio-redis:latest         "/start.sh"              5 hours ago   Exited (0) 8 seconds ago                nextcloud-aio-redis
b1b3ca7ddb44   ghcr.io/nextcloud-releases/aio-postgresql:latest    "/start.sh"              5 hours ago   Exited (0) 7 seconds ago                nextcloud-aio-database
da7dccd04873   ghcr.io/nextcloud-releases/aio-notify-push:latest   "/start.sh"              5 hours ago   Exited (143) 8 seconds ago              nextcloud-aio-notify-push
0618f5ac2b33   ghcr.io/nextcloud-releases/aio-collabora:latest     "/start.sh"              5 hours ago   Exited (0) 7 seconds ago                nextcloud-aio-collabora
c7df95de617c   ghcr.io/nextcloud-releases/aio-borgbackup:latest    "/start.sh"              5 hours ago   Exited (0) 5 hours ago                  nextcloud-aio-borgbackup
95eb424e9eb8   ghcr.io/nextcloud-releases/aio-watchtower:latest    "/start.sh"              5 hours ago   Exited (0) 5 hours ago                  nextcloud-aio-watchtower
In order to fix it, I have to do the following:
  1. docker compose down
  2. restart the docker service
  3. docker stop all containers and remove them
  4. docker container prune to get rid of the nextcloud-aio-apache container
  5. docker compose up
  6. Go to the NC AIO page and pull/start all the sub-containers
Well, still having the nextcloud-aio-apache container is in a Created state crash every 4 - 5 days. I finally realized it was inevitable and likely something I would just have to live with. So, I figured out how to restart everything via bash. Those commands are here. The docker ps -a are just so I can see the progress. The docker exec at the end will restart all the NextCloud AIO sub-containers.
cd /var/lib/docker
docker ps -a
docker container prune -f
docker ps -a
docker compose down
docker ps -a
docker rm -f $(docker container ls -q --filter name=nextcloud*)
docker ps -a
service docker restart
docker compose up -d --pull always
docker ps -a
docker exec -it nextcloud-aio-mastercontainer sudo -u www-data php /var/www/docker-aio/php/src/Cron/StartAndUpdateContainers.php
docker ps -a
From there I started thinking about how to automate this so I wasn’t having to manually do it every time the site crashed. It could be hours between when it crashed and when I noticed or someone messaged me. I figured a website checking script would probably do what I needed. I searched and found one and then adopted it in to a bash script.
Here is that checking script that also does the restart when it encounters a 503. It also sends me an email and text (Verizon email-to-text). I am using mutt/msmtp for this on Ubuntu sending through Gmail. I am not covering that setup, but can if someone really needs it.
Storage.Website.Errors.sh
#!/bin/bash
#Purpose = Checker to see if Storage site is up. If 502 error, restart docker.
#START
# Variables
RECIPIENT="DanGilbertTX@aol.com"
TEXTRECIPIENT="8888675309@vtext.com"
SUBJECT="Forced to reset 502 for Storage on $(date +%A", "%B" "%d", "%Y)"
MESSAGE="The script found a 502 error and executed the reset script on Storage for docker. Please check to make sure it worked."
NON502SUBJECT="The website is down for Storage for an unknwon reason on $(date +%A", "%B" "%d", "%Y)"
NON502MESSAGE="The website is down for Storage for some unknown reason. Please check it."
response=$(/usr/bin/curl -s -o /dev/null -w "%{http_code}" https://storage.myredactedsite.org/s/Shared)
if [ "${response}" == "200" ]; then
    # Everything looks good. No need for a notification.
    echo "Website is up and working!"
elif [ "${response}" == "502" ]; then
    echo "502 error. Resetting docker."
    cd /var/lib/docker
    /usr/bin/docker container prune -f
    /usr/bin/docker compose down
    /usr/bin/docker rm -f $(docker container ls -q --filter name=nextcloud*)
    /usr/sbin/service docker restart
    /usr/bin/docker compose up -d --pull always
    /usr/bin/docker exec -it nextcloud-aio-mastercontainer sudo -u www-data php /var/www/docker-aio/php/src/Cron/StartAndUpdateContainers.php
    echo $MESSAGE | /usr/bin/mutt -F "/root/.muttrc" -s "$SUBJECT" "$RECIPIENT"
    echo $MESSAGE | /usr/bin/mutt -F "/root/.muttrc" -s "$SUBJECT" "$TEXTRECIPIENT"
else
        echo "Website is down!"
        echo $NON502MESSAGE | /usr/bin/mutt -F "/root/.muttrc" -s "$NON502SUBJECT" "$RECIPIENT"
fi
After testing it multiple times to make sure it works and sends email/text, I added it to cron to run every 15 minutes. I figure that it as a very acceptable RTO.
Also, make sure to chmod 755 Storage.Website.Errors.sh so that bash can execute the script.
*/15 * * * * /root/Storage.Website.Errors.sh
NOTE: I am running it as root and that is “bad”, however I know the risks and decided on it anyway. YMMV. You do you boo.
Finally, I would LOVE to fix the root cause, but I can live with this solution for a long time. Especially since it is now “automated” to fix itself for the standard 502 crash I am experiencing. I also learned a bit about scripting for docker and NC AIO during this process, so that is a bonus.
Marking it solved for now even though the root cause is not remediated. There is a solution to restart the services upon failure that will suffice.
