Nextcloud version: 12.0.4
Operating system and version: WSL Ubuntu 16
Apache or nginx version: Apache 2.4.18
PHP version: 7.2
I’ve got a working Nextcloud installation. I can view the files in my browser and can connect to WebDav with Cyberduck.
However, when I try to run the Curl example from the doc, I’m getting an error “405 Method Not allowed” and indeed the PROPFIND method is not among the allowed methods.
$ curl -v -X PROPFIND -H "Depth: 1" -u admin:****** http://nextcloud.local/nextcloud/remote.php/dav/files/admin/
* Trying 127.0.0.136...
* Connected to nextcloud.local (127.0.0.136) port 80 (#0)
* Server auth using Basic with user 'admin'
> PROPFIND /nextcloud/remote.php/dav/files/admin/ HTTP/1.1
> Host: nextcloud.local
> Authorization: Basic ********
> User-Agent: curl/7.47.0
> Accept: */*
> Depth: 1
< HTTP/1.1 405 Method Not Allowed
< Date: Fri, 19 Jan 2018 13:48:38 GMT
< Server: Apache/2.4.18 (Ubuntu)
< Allow: GET,HEAD,POST,OPTIONS
< Content-Length: 344
< Content-Type: text/html; charset=iso-8859-1
<!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN">
<html><head>
<title>405 Method Not Allowed</title>
</head><body>
<h1>Method Not Allowed</h1>
<p>The requested method PROPFIND is not allowed for the URL /nextcloud/remote.php/dav/files/admin/.</p>
<hr>
<address>Apache/2.4.18 (Ubuntu) Server at nextcloud.local Port 80</address>
</body></html>
* Connection #0 to host nextcloud.local left intact
Any idea what could be the issue? Are there some more headers that I need to provide to get it working? I see that Cyberduck is making PROPFIND requests without any problem so I’m most likely missing something.
For information, this is the kind of calls that CyberDuck makes and it works:
PROPFIND /remote.php/dav/files/admin/Documents/ HTTP/1.1
Depth: 1
Content-Type: text/xml; charset=utf-8
Content-Length: 242
Connection: Keep-Alive
User-Agent: Cyberduck/6.3.5.27408 (Windows 10/10.0) (x86)
Cookie: cookie_test=test; nc_sameSiteCookielax=true; nc_sameSiteCookiestrict=true; oc_sessionPassphrase=*****************
Accept-Encoding: gzip,deflate
Authorization: ********
