I installed NextCloudPi into a Digital Ocean droplet (Ubuntu 20) using Docker. The container starts successfully but when I try to access it I get “Forbidden”. I used the IP of the server for the DOMAIN parameter. I think I followed the instructions properly, but did I miss something?
The container logs show:
System config value trusted_domains => 6 set to string
I opened HTTP and HTTPS access through the firewall in my droplet.
I encountered the same problem when installing nextcloud using the official basic docker-compose file provided.
I solved the problem with the following command.
Stop and remove all your nextcloud containers.
# with docker-compose
docker-compose stop
docker-compose rm
# if without docker-compose
docker ps
docker stop nextcloud
docker stop mariadb
docker rm nextcloud
docker rm mariadb
Then try deleting your docker volume and restarting docker compose.
