I installed nextcloud on nginix using the example configuration script provided to install under a subfolder nextcloud on my webserver. I’ve noted that while the majority of the application seems to work, I get errors in my log file as follows:
access.log
- [26/Apr/2017:15:09:01 +0100] “POST /nextcloud/settings/users/users HTTP/2.0” 403 15858 “-” “Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:53.0) Gecko/20100101 Firefox/53.0”
To get this error yourself, try and add a user, but provide a password that is inadequate - you should get a popup if I recall correctly from using this with apache, but you get no feedback, the “create” button just does nothing.
Presumably the configuration file for nginix is incorrect and I need to alter it to allow access to the users.php file, but I’ve tried a number of guesses based on the other entries in the file already and none have worked. Please can someone say the alteration that is required. Thanks.
