Note that ownCloud 10.0.1 can not yet be migrated to Nextcloud 12, we are still testing this upgrade path to make sure it is 100% reliable!
So I guess nothing changed about that so far. But I would also see some priority in that since an easy safe migration is still the one of the most important thing bringing people to use Nextcloud. I wonder what the reasons are that this take so long or if it is already solved for coming minor release. I will have a look at github.
The minor release of NC 12.0.1 is a bit delayed, so probably all other milestones are delayed as well. If you are not already on NC 12, I would wait for this minor release. If you need to get away from ownCloud urgently, you still need a bit of manual work, in many cases it should be acceptable to wait another 1-2 weeks.
Here is the migration bug report on github:
Nextcloud 12.0.1RC4 - HELP TEST! -> Nextcloud 12.0.1RC4 supports upgrading from oC 10.0.1 and 10.0.2, I tested it and we can use some more testing help!
It should be out in a few days, provided no issues are found.
Today I migrated from OC 10.0.2 to NC 12.0.1 in a testing environment with success. I had dared to do so, because the annoucement of NC 12.0.1 promised to have fixed the migration issue.
Please note:
I have not been able to use the migration tool, since it still said, that there was no upgrade path from OC 10.0.2 to NC 12. So I took the manual way of migrating as decribed above.
I am very confused!
Iām trying to migrate from ownCloud 10.0.3.3 to Nextcloud 12.0.4 but get the error:
Current version is 10.0.3.
Could not determine migration path to Nextcloud.
I have been waiting for Nextcloud 12.0.4 as I understood this would support migration from ownCloud 10.0.3.
Am I wrong or am I doing something wrong?
Thanks,
Cliff
Iām exactly in the same situation (owncloud 10.0.3.3), I have been waiting for the newer version during 3 months, I had understood on some forums that we must wait for the 12.0.4ā¦
Is there any progress on this? Iām stuck in limbo at the moment - I want to migrate to Nextcloud but canāt because the migration script doesnāt work, and I donāt want to upgrade my ownCloud instance because migration from ownCloud 10.0.4 to Nextcloud doesnāt seem to be supported.
Thanks,
Cliff
Thanks for the suggestion but Iām not comfortable with ānot sure if⦠could workā and 'If you are lucky it just works." I would rather wait for this problem to be fixed.
Thanks.
I said luckily because I havenāt seen any feedback on the upgrade process itself. But the issue you are running into is just that the migration path is not detected correctly. The manual upgrade is probably working quite good, and with a complete backup the risk should be manageable. But it is ok to wait for the issue to be fixed.
If youāre using sqlite as your data store, you can make a complete and re-usable backup by copying your owncloud directory to a backup directory with cp -r owncloud owncloud-10 ā if the upgrade process described at ā3 reasons to upgrade your ownCloud instance to Nextcloud and how easy it is - #31 by tfliddā fails, you can restore your backup easily with mv owncloud nextcloud-12; mv owncloud-10 owncloud. (you could also just delete owncloud and move owncloud-10 back into itās place but Iām superstitious so I donāt delete until I know I didnāt scramble the commands and delete the thing I need.
If youāre not running sqlite there are definitely instructions on how to backup your database and then restore from the backup.
If you do want help figuring out how to ensure that youāll be able to restore your work OwnCloud instance from a back up if the migration fails, you probably need to provide more detail about what you are running.
