Effective March 30, 2024, Duo Security will no longer support the traditional Duo Prompt. This will mean no longer supporting the iFrame experience in the Duo Prompt or any dependencies on the iFrame.
Experimental New Method Two-Factor DUO Universal Prompt for Nextcloud
Tested on Nextcloud versions 27, 28, and 29
Add your duo configuration to your Nextcloud’s nextcloud/config/config.php fils:
'twofactor_duo' => [
'IKEY' => 'xxx',
'SKEY' => 'yyy',
'HOST' => '*.duosecurity.com',
'CALL' => 'https://example.com/login/callback/duo',
Nextcloud Lib Patch
nextcloud/lib/public/Authentication/TwoFactorAuth/IProvider.php
nextcloud/lib/private/Authentication/TwoFactorAuth/Manager.php
nextcloud/apps/twofactor_backupcodes/lib/Provider/BackupCodesProvider.php
public function verifyChallenge(IUser $user, string $challenge): bool;
Change to: (remove the word string)
public function verifyChallenge(IUser $user, $challenge): bool;
Nextcloud Core Patch
nextcloud/core/routes.php
['name' => 'TwoFactorChallenge#solveChallenge', 'url' => '/login/challenge/{challengeProviderId}', 'verb' => 'POST'],
After that line, add this:
['name' => 'TwoFactorChallenge#solveChallenge', 'url' => '/login/callback/{challengeProviderId}', 'verb' => 'GET'],
