A problem with talk and circles was found and fixed so we did a quick update, please test! 22.1.1RC1 should be on the download servers - get it from the beta channel or download on: https://download.nextcloud.com/server/prereleases/
I am hoping a fix can be implemented for the problem of being unable to share boards in Deck (contacts lookup fails in sharing section of Details - the search progress wheel keeps spinning to no avail). Pretty hard to do project planning if the team can’t see the tasks and deadlines assigned to them…
“With this release, we adopt semantic versioning. 10 This will make it more clear what is contained in a release. As we introduce a minor feature, the multiple-email support, we therefor release this as 22.1.0, not 22.0.1.”
The 10 means endless bugs for me. Upgrade from 21 to 22 was a big mess. For me everything worked just fine before and with this release I have many issues. The RC1 did not change anything.
No one answering my post since 8 days as well.
I would expect at least an answer.
Release candidates are ‘test versions’, meaning bugs with it can be directly reported to the developers. If this bug existed before, make sure that it was reported to github and it is supposed to be solved with this release candidate. If it is supposed to solve the issue and it doesn’t for you, please report again to the bug tracker.
With my productive system, I’m a bit more careful. But this is especially because of apps that I use that they might not be ready directly at the release of the new version (mainly from developers from the community). A bit surprising that it were ‘official apps’ this time where they added some functions…
That’s an issue with the security scanner not with the NC 22.1.1.2 release or your installation. There are multiple issues open on Github regarding this…
