I am simply trying to get the Nextcloud plugin working. I’ve done a lot of googling, and nobody else seems to have this issue.
This is a fresh FreeNAS installation, and subsequent Nextwave Plugin installation. The Plugin seems to install without issue, but when I click on Management, it takes me to a general login page, not the mangement page. Please see the screenshots I’ve attached.
Full disclosure, I am brand new to FreeNAS as well as Nextcloud.
Your FreeNAS is the 11.3 and the video guide you followed is for 11.2.
Maybe try this instead?
Or maybe start with FreeNAS 11.2?
If you are serious about running Nextcloud, install a Ubuntu virtual machine and then Nextcloud on it (aka normal install). Will save you a lot of headaches down the road…
