Would you mind explaining exactly how to solve this with apache2 please?
For apache2 there is a .htaccess file with the “solution” so there is nothing to be done:
… unless you disabled .htaccess by server configuration with
AllowOverride None
ernolf
Thanks, the only AllowOverride statement I have is in my site configuration file like this:
Require all granted
AllowOverride All
Options FollowSymLinks MultiViews
<IfModule mod_dav.c>
Dav off
</IfModule>
</Directory>
But I still see the warning in Nextcloud. I checked the .htaccess file in /var/www/nextcloud and it contains those directives. Any suggestions?
The problem when using old topics, is that you did not provide any information about your system, your setup and your hosting environment.
Are you on a shared hoster?
It only works if the apache2 module mod_env is loaded.
If you have got full access to your webserver, you could find out if mod_env is loaded with this call
~$ sudo apachectl -M 2>/dev/null | grep env_module
it should echo this:
env_module (shared)
Much and good luck,
ernolf
Thanks, yes the output of
is
env_module (shared)
In my case I am running nextcloud on my own server with a bare install (no containers). I’ve been running it this way since about NC 13, but the headers warning seems to be since upgrading to NC 29.
My full apache site config is below:
<IfModule mod_ssl.c>
<VirtualHost *:443>
# enable HTTP/2
Protocols h2 http/1.1
# The ServerName directive sets the request scheme, hostname and port that
# the server uses to identify itself. This is used when creating
# redirection URLs. In the context of virtual hosts, the ServerName
# specifies what hostname must appear in the request's Host: header to
# match this virtual host. For the default virtual host (this file) this
# value is not decisive as it is used as a last resort host regardless.
# However, you must set it for any further virtual host explicitly.
ServerName <redacted>
<IfModule mod_headers.c>
Header always set Strict-Transport-Security "max-age=15552000; includeSubDomains"
</IfModule>
ServerAdmin sysadmin@<redacted>
DocumentRoot /var/www/nextcloud
Require all granted
AllowOverride All
Dav off
</IfModule>
</Directory>
# For most configuration files from conf-available/, which are
# enabled or disabled at a global level, it is possible to
# include a line for only one particular virtual host. For example the
# following line enables the CGI configuration for this host only
# after it has been globally disabled with "a2disconf".
#Include conf-available/serve-cgi-bin.conf
<IfModule mod_rewrite.c>
RewriteEngine on
# to prevent direct logins
#RewriteCond %{QUERY_STRING} direct
#RewriteRule ^login$ - [R=404]
# well-known
RewriteRule ^/\.well-known/host-meta /public.php?service=host-meta [QSA,L]
RewriteRule ^/\.well-known/host-meta\.json /public.php?service=host-meta-json [QSA,L]
RewriteRule ^/\.well-known/carddav /remote.php/dav/ [R=301,L]
RewriteRule ^/\.well-known/caldav /remote.php/dav/ [R=301,L]
RewriteRule ^\.well-known/nodeinfo /index.php/.well-known/nodeinfo [R=301,L]
RewriteRule ^\.well-known/webfinger /index.php/.well-known/webfinger [R=301,L]
</IfModule>
# Available loglevels: trace8, ..., trace1, debug, info, notice, warn,
# error, crit, alert, emerg.
# It is also possible to configure the loglevel for particular
# modules, e.g.
#LogLevel info ssl:warn
ProxyPass /push/ws ws://127.0.0.1:7867/ws
ProxyPass /push/ http://127.0.0.1:7867/
ProxyPassReverse /push/ http://127.0.0.1:7867/
SSLCertificateFile /etc/letsencrypt/live/<redacted>/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/<redacted>/privkey.pem
</VirtualHost>
</IfModule>
I’m in exactly same case :
- Server Ubuntu 20.04 (updated)
- PHP 8.2.20
- Apache 2.4.41
http headers give this log :
- HTTP/1.1 301 Moved Permanently
- Date: Mon, 17 Jun 2024 08:25:26 GMT
- Server: Apache/2.4.41 (Ubuntu)
- Content-Length: 312
- Connection: close
- Content-Type: text/html; charset=iso-8859-1
- HTTP/1.1 200 OK
- Date: Mon, 17 Jun 2024 08:25:27 GMT
- Last-Modified: Sun, 16 Jun 2024 18:13:00 GMT
- ETag: “9c-61b05cc8b06c2”
- Accept-Ranges: bytes
- Content-Length: 156
- Vary: Accept-Encoding
- X-Frame-Options: sameorigin
- Connection: close
Apache Config :
<VirtualHost *:80>
ServerName myserver.com
ServerAdmin webmaster@localhost
DocumentRoot /var/www/html
<Directory /var/www/html>
Options -Indexes
</Directory>
RewriteEngine on
RewriteCond %{SERVER_NAME} =myserver.com
RewriteRule ^ https://%{SERVER_NAME}%{REQUEST_URI} [END,NE,R=permanent]
<Directory /var/www/html/nextcloud/>
Require all granted
AllowOverride All
Dav off
</IfModule>
</Directory>
</VirtualHost>
Loaded modules :
core_module (static)
so_module (static)
watchdog_module (static)
http_module (static)
log_config_module (static)
logio_module (static)
version_module (static)
unixd_module (static)
access_compat_module (shared)
alias_module (shared)
auth_basic_module (shared)
authn_core_module (shared)
authn_file_module (shared)
authz_core_module (shared)
authz_host_module (shared)
authz_user_module (shared)
autoindex_module (shared)
deflate_module (shared)
dir_module (shared)
env_module (shared)
filter_module (shared)
headers_module (shared)
mime_module (shared)
mpm_prefork_module (shared)
negotiation_module (shared)
php_module (shared)
reqtimeout_module (shared)
rewrite_module (shared)
setenvif_module (shared)
socache_shmcb_module (shared)
ssl_module (shared)
status_module (shared)
.htaccess in /var/www/html/nextcloud :
<IfModule mod_setenvif.c>
<IfModule mod_fcgid.c>
SetEnvIfNoCase ^Authorization$ "(.+)" XAUTHORIZATION=$1
RequestHeader set XAuthorization %{XAUTHORIZATION}e env=XAUTHORIZATION
</IfModule>
<IfModule mod_proxy_fcgi.c>
SetEnvIfNoCase Authorization "(.+)" HTTP_AUTHORIZATION=$1
</IfModule>
<IfModule mod_lsapi.c>
</IfModule>
</IfModule>
<IfModule mod_env.c>
# Add security and privacy related headers
# Avoid doubled headers by unsetting headers in "onsuccess" table,
# then add headers to "always" table: https://github.com/nextcloud/server/pull/19002
Header onsuccess unset Referrer-Policy
Header always set Referrer-Policy "no-referrer"
Header onsuccess unset X-Content-Type-Options
Header always set X-Content-Type-Options "nosniff"
Header onsuccess unset X-Frame-Options
Header always set X-Frame-Options "SAMEORIGIN"
Header onsuccess unset X-Permitted-Cross-Domain-Policies
Header always set X-Permitted-Cross-Domain-Policies "none"
Header onsuccess unset X-Robots-Tag
Header always set X-Robots-Tag "noindex, nofollow"
Header onsuccess unset X-XSS-Protection
Header always set X-XSS-Protection "1; mode=block"
SetEnv modHeadersAvailable true
</IfModule>
# Add cache control for static resources
<FilesMatch "\.(css|js|mjs|svg|gif|png|jpg|ico|wasm|tflite)$">
<If "%{QUERY_STRING} =~ /(^|&)v=/">
Header set Cache-Control "max-age=15778463, immutable"
</If>
<Else>
Header set Cache-Control "max-age=15778463"
</Else>
</FilesMatch>
# Let browsers cache WOFF files for a week
<FilesMatch "\.woff2?$">
Header set Cache-Control "max-age=604800"
</FilesMatch>
</IfModule>
<IfModule mod_php.c>
php_value mbstring.func_overload 0
php_value default_charset 'UTF-8'
php_value output_buffering 0
SetEnv htaccessWorking true
</IfModule>
</IfModule>
<IfModule mod_mime.c>
AddType image/svg+xml svg svgz
AddType application/wasm wasm
AddEncoding gzip svgz
# Serve ESM javascript files (.mjs) with correct mime type
AddType text/javascript js mjs
</IfModule>
<IfModule mod_dir.c>
DirectoryIndex index.php index.html
</IfModule>
<IfModule pagespeed_module>
ModPagespeed Off
</IfModule>
RewriteEngine on
RewriteCond %{HTTP_USER_AGENT} DavClnt
RewriteRule ^$ /remote.php/webdav/ [L,R=302]
RewriteRule .* - [env=HTTP_AUTHORIZATION:%{HTTP:Authorization}]
RewriteRule ^\.well-known/carddav /nextcloud/remote.php/dav/ [R=301,L]
RewriteRule ^\.well-known/caldav /nextcloud/remote.php/dav/ [R=301,L]
RewriteRule ^\.well-known/webfinger /nextcloud/index.php/.well-known/webfinger [R=301,L]
RewriteRule ^\.well-known/nodeinfo /nextcloud/index.php/.well-known/nodeinfo [R=301,L]
RewriteRule ^remote/(.*) remote.php [QSA,L]
RewriteRule ^(?:build|tests|config|lib|3rdparty|templates)/.* - [R=404,L]
RewriteRule ^\.well-known/(?!acme-challenge|pki-validation) /index.php [QSA,L]
RewriteRule ^ocm-provider/?$ index.php [QSA,L]
RewriteRule ^(?:\.(?!well-known)|autotest|occ|issue|indie|db_|console).* - [R=404,L]
</IfModule>
https://docs.nextcloud.com/server/latest/admin_manual/issues/general_troubleshooting.html#troubleshooting-webdav
SetEnvIf Transfer-Encoding "chunked" proxy-sendcl=1
</IfModule>
AddDefaultCharset utf-8
Options -Indexes
#### DO NOT CHANGE ANYTHING ABOVE THIS LINE ####
ErrorDocument 403 /nextcloud/index.php/error/403
ErrorDocument 404 /nextcloud/index.php/error/404
And I’m still having this issue : Some headers are not set correctly on your instance …
Any help would be really appreciated
Ok, so I just found where the issue come from for my own case.
I did not realized there was a separate file for SSL.
Once I did realized this I addzd this in the SSL conf file and now headers are well handled :
Require all granted
AllowOverride All
Dav off
</IfModule>
</Directory>
Hi guys,
I found the problem : the code running test is base on doing GET on /heartbeat. But apparently, this route has a problem : fix(settings): define a 'heartbeat' route, so SecurityHeaders can handle redirected root by smokris · Pull Request #45228 · nextcloud/server · GitHub
Fix is scheduled so : wait or manually set URL in apps/settings/lib/SetupChecks/SecurityHeaders.php
Replace
public function run(): SetupResult {
$urls = [
['get', $this->urlGenerator->linkToRoute('heartbeat'), [200]],
by
$urls = [
['get', '/heartbeat' , [200]],
Yep. The latest update of NC fixed this issue. I was going nuts trying to figure out if my instance is not setup correctly as I am using HAProxy on pfsense.
Now it’s all good. ![]()
Yep the fix works ![]()
