I updated my previous post.
And yes I assume too that ncp
is not www-data
, but what if ncp executes the sudo -u www-data
would that raise that error too ?
is not www-data
I think that does not help us. But you can post the sudo configuration for user ncp
. I think the command is possible (without password for ncp
→ www-data
) with sudo permissions. Perhaps it is not possible at all.
the ncp user is not in the sudoers file nor in a group mentioned in my sudoers file. from my understanding ncp is not allowed to use sudo
sudo -u ncp sudo -u www-data php /var/www/nextcloud/occ status | grep "version:" | awk '{ print $3 }'
We trust you have received the usual lecture from the local System
Administrator. It usually boils down to these three things:
#1) Respect the privacy of others.
#2) Think before you type.
#3) With great power comes great responsibility.
[sudo] password for ncp:
I do not know the password
Perhaps it is not necessary. I think the error we only find in (wrong) interaction between www-data
and root
good catch. I found where this happens, nothing is really broken but we were using the wrong invocation during the sidebar loading so we get this harmless warning. Fixed
@nachoparker
@devnull thanks for your patience and help, wouldn’t have started to look deeper into this without you asking questions
Seems it gets solved with
