That one. You can edit it right away and make a PR out of it
Now wrt the whole ‘supported’ debate, looking at the documentation and stuff, it is a bit of a pita term, so I want to say sorry to @JaredBusch on that one. Eg if you see like “minimum supported PHP version 5.6” vs what distro is supported or recommended - that is all confusing.
When it comes to the PHP version, ‘supported’ means “we’ll ignore bug reports about stuff that isn’t working with older versions”, while with distro’s it is generally so that any LAMP stack with the right minimum versions means our contributors won’t ignore bug reports unless there’s a big red flag for that distro shipping something horribly broken.
So I guess that that is what supported means - and it is only applied to the bare minimum requirements, not to specific platforms, that is more of an enterprise thing. Hence no “this is supported and this isn’t” for the distro or the method of installing PHP 7: each is equally well accepted.
Awesome, I’ll do some more testing and I’ll get right on that. That will provide a bit of the warm and fuzzies that I think a lot of us are looking for. Maybe I can get on Suse as well once that is done.
And I finally found/noticed that farther down in the install documentation it clearly states that the use of SCL is the only recommended method of getting PHP 5.5 (likely copied from the old ownCloud guide). So that is the official answer, IMO, that I was looking for.
CentOS 7 provides PHP version 5.4 in its official repository
Command to install the EPEL repository configuration package:
yum install https://dl.fedoraproject.org/pub/epel/epel-release-latest-7.noarch.rpm
Command to install the Remi repository configuration package:
yum install http://rpms.remirepo.net/enterprise/remi-release-7.rpm
Command to install the yum-utils package (for the yum-config-manager command):
yum install yum-utils
You want a single version which means replacing base packages from the distribution
Packages have the same name than the base repository, ie php-*
PHP version 7.1 packages are available for CentOS 7 in remi-php71 repository
Command to enable the repository:
yum-config-manager --enable remi-php71
Command to upgrade (the repository only provides PHP):
yum update
@Therion7777 That is not supported. The official answer is that there is no supported method to get PHP > 5.4 except via SCL as SCL is what RHEL will support.
