No problem. Iām thankful for help.
Module rewrite already enabled
It would be halpful if Nextcloud would tell me, where the problem is, because if NC can say me that there is a problem, it have to prove files or whatever.
Hey, I have a similar issue.
Although the redirection works fine, the overview tab in the nextcloud settings gives me the error. I am using nextcloud:apache inside docker behind an nginx proxy. Can anyone relate?
I am having exactly the same issueā¦
The docker image is missing key features aswell, kinda anoyed about that
I think I will look for a modded version by someone.
EDIT:
I have to correct myself! Nextcloud Developers thought about that and offered a solution which I didnāt get firstā¦
The solution for the āfeature problemā is simply Dockerfile full: (this one is for the apache image, there are examples for all images)
Put these files into a folder next to your docker-compose like āappā in my case.
In your docker-compose.yml
nextcloud:
build: ./app
instead of
nextclouod:
image: nextcloud
Now just docker-compose build --pull
and docker-compose up -d
Really easy and awesome solution for custom containers, thanks!
Donāt mean to hijack the thread but I am having the same issue and canāt find a solution to fix itā¦
I am using Proxmox VM for 1-2 years, sometimes the updates have a couple of hickups but been able to fix them searching here or in github for solutions.
This one, I canāt find anything that fixes it
My /var/www/nextcloud/.htaccess file has the correct content and this was working fine. I think a ntp update also upgraded php7.1 to php8.1 and problems startedā¦
<IfModule mod_rewrite.c>
RewriteEngine on
RewriteCond %{HTTP_USER_AGENT} DavClnt
RewriteRule ^$ /remote.php/webdav/ [L,R=302]
RewriteRule .* - [env=HTTP_AUTHORIZATION:%{HTTP:Authorization}]
RewriteRule ^\.well-known/carddav /remote.php/dav/ [R=301,L]
RewriteRule ^\.well-known/caldav /remote.php/dav/ [R=301,L]
RewriteRule ^remote/(.*) remote.php [QSA,L]
RewriteRule ^(?:build|tests|config|lib|3rdparty|templates)/.* - [R=404,L]
RewriteRule ^\.well-known/(?!acme-challenge|pki-validation) /index.php [QSA,L]
RewriteRule ^(?:\.(?!well-known)|autotest|occ|issue|indie|db_|console).* - [R=404,L]
</IfModule>
Anything else I can do?
Nice to see Iām not alone with that problem! Rewrite is just a riddle I cannot solveā¦
I started dealing with Nextcloud only a few days ago and this was a major time killer until I found someone (I think on stackoverflow) not using rewrite but headers module to solve it.
My nextcloud and mariadb run in containers exporting https on port 9443 on a nas with hostname qnap and the apache proxy runs on another host.
So my apache proxy configuration for nextcloud now looks like this and those errors/warnings are gone:
Header always set Strict-Transport-Security "max-age=15552000; includeSubDomains; strict-origin; preload"
Redirect 301 /.well-known/carddav /nextcloud/remote.php/dav
Redirect 301 /.well-known/caldav /nextcloud/remote.php/dav
Redirect 301 /.well-known/webfinger /nextcloud/index.php/.well-known/webfinger
Redirect 301 /.well-known/nodeinfo /nextcloud/index.php/.well-known/nodeinfo
ProxyPreserveHost "off"
SSLProxyVerify "none"
SSLProxyCheckPeerName "off"
ProxyRequests "off"
SSLProxyEngine "on"
<Location "/nextcloud">
ProxyPass "https://qnap:9443"
ProxyPassReverse "https://qnap:9443"
</Location>
You have to enable the apache module headers for that, not rewrite.
And at least while debugging apache config I would not use IfModule. Then you immediately see if needed modules are enabled or not when starting apache. One less cause for errors.
I donāt know of any downsides for this solution, and it works so it canāt be that bad Hope it helps!
