why can’t there be an update without having to do some extra stuff
i run my NC’s at shared hosting, there is no change of running those commands.
is there any other way of fixing it?
I’m seeing the same warning on my instance. I’m running nextcloudpi on raspberrypi. When I enter ‘sudo -u www-data php occ db:convert-filecache-bigint’ I get ‘could not open inout file: occ’
What is the right command for nextcloudpi? And is it enough to put the instance in maintenance mode ?
And how am I going to run this command in CentOS 7? Can someone please help me on having compatible command for CentOS 7 ?
Thanks!
I have the same question do you have a solution?
See JanDragon’s post above. That works on Centos 7.
As I had the same problem - no SSH access - I used the possibility to create a cron job in the backend of my hoster and called the script from there, in my case:
/usr/bin/php /usr/www/users/xxx/cloud.xxx.com/occ db:convert-filecache-bigint --no-interaction
The “–no-interaction is necessary” - otherwise the script would “ask” to continue.
It’s probably also possible to create a temporary php script to execute “occ” from a system() call, maybe like this:
$cmd = "/usr/bin/php /usr/www/users/xxx/cloud.xxx.com/occ db:convert-filecache-bigint --no-interaction";
system($cmd,$return_value);
($return_value == 0) or die("returned an error: $cmd");
