if youâd translate âbureaucratâ as taking care about what happens on the forum youâd be absolutely right. Thatâs excatly the job of a moderator. Well detected.
again and again and again: Nextcloud can do nothing, but nothing at all to solve the problem.
Every expectation beyond that is not realistic.
As already (!) said above if there were 1000âs of complaints on the Github-issue it would get a high(er) priority.
Call it unfair or not user-friendly but thatâs the way Open Source goes. And weâre not here to change that. If you want to make yourself heard go and buy official support.
correct for 100% - thanks for bringing that out again (!).
sure enough,but would you really expect that MB would change their standards, because 10 ppl said they didnât like the goodyears?
it really is. But this discussion shiftâs more and more to a direction which is out of reach for Nextcloud.
And yes, some (as in âanother fewâ) ppl agreed upon the problem but again which is nice but meaningless because that happens on a 3rd party forum for Collabora.
And it the faulty behaviour sounds really like a bug in Collabora. And hence there is a bug report on their repro.
the forum is here to have a place where (mostly homeusers) are hoping to find help from some other, maybe more experienced, users who are here on a voluntary basis. They spend their sparetime here and they donât get paid.
Why is that forum? Because Nextcloud (the software) is free to use for anyone but in exchange it comes with (almost) 0 support. Apart from the hints you can gather here on the forum.
Sure you can discuss anything here⌠like: I donât like the weather⌠what do you think about it?
and sure enough it would go a similar way as this discussoin: âletâs complain about it and make someone responsible for that to change it.â
if Iâd go through the whole discussion on here I think that everything was already said, there wonât be any new aspects to it. The situation was described well enough several times, the solution (at least for this forum) was also told several times.
Everything else will only prolong the âdiscussionâ.
So this one is gonna close automatically after 24 more hours to just give everyone a fair chance to speak their mind a last time.
