Will do in a bit, thanks.
Any plans when we will see the final release?
The final was release last thursday. as per above “get it now”
You have to do an manual update…
…perhaps for the last time…
Thank you for your great work. Manual upgrading works well, no problems at all on my Raspberry Pi. Just a little mistake in your upgrade instructions: The command sudo -u www-data php occ maintenance:mode --off is not necessary, occ upgrade does it on itself.
Once again: Thank you!
A new fresh installation (MariaDb/MySQL) gives me the following error:
Error while trying to create admin user: Failed to connect to the database: An exception occured in driver: SQLSTATE[HY000] [1044] Access denied for user ‘oc_cta4’@‘localhost’ to database …
The Installer use always an oc_cta(#) db-user. My db-user-name was ignored.
Please create a new topic in the support section
