RC1 of Desktop Client 2.5 is out
It’s not actually an old version of OpenSSL. It doesn’t show the actual version being used. The old version is included as well, but it’s not active/compiled with it.
any chance you could test with the 2nd RC? And reply in the issue? It might qualify as release blocker :wink: though that’s a decision for the devs, not me.
I’ll give it a shot. IMHO, it should be a release blocker, as if you are using the client and have E2E enabled on the server, it won’t work at all. (if you use nginx)
Update: https://github.com/nextcloud/desktop/issues/560?_pjax=%23js-repo-pjax-container#issuecomment-436005703
Still broken.
@jospoortvliet It is final now?
https://download.nextcloud.com/desktop/releases/Windows/
See the release blog :wink: we’re already working on a 2.5.1!
