Problem after Updating to v28
because the value depends on the timezone you’re in, and when you want the maintainenance window to start.
I don’t use the NC Docker images, but as far as I understand it, that’s what environment variables are for: GitHub - nextcloud/docker: :ferry: Docker image of Nextcloud
My previous post obviously was about the maintenance_window_start parameter.
As for the bz2 package, I honestly don’t understand it either, why they don’t just include it. There’s a discussion about it on GitHub, and as far as I can remember it’s only needed in very few situations, so you can probably just ignore the warning.
truly, NC is a big machinery and you can die tryin’
I’m not using sudo if i need to log in and access the container, I lazily use root huhu
But we all know I wouldn’t do that in my Debian, right?
peace :v:
Easy way to do this:
  1. Delete all entery in /path/to/nextcloud/data/nextcloud.log
  2. add ā€˜logfile’ => ā€˜/path/to/nextcloud/data/nextcloud.log’, to /path/to/nextcloud/config/config.php
  3. done
