No access to my nextcloudpi trough my fritzbox
Sorry. but you should read more carefully, that is how this thread started, first post.
No need to be impatient and rude, next time we hear from MP28, he tells us server is up and running, activated and all is fine
:grinning_face:
Thank you geoW for the helpful information.
I finally hooked the pi up to my pc monitor, because I still don’t can accessing it, with the monitor in place no image at all.
I be now flashing the Sd card with the nativ raspberry pi os desktop version to see, if I maybe get a faulty Bord wo cause the trouble and if I can accessing it remotely for test.
Try flashing an raspberry os, so you check board and sd card, if in doubt.
Keep in mind - bare ncp-image flash – no presets.
Good luck.
Hallo, I think I be a big step forward, the pi is defective, what friend the Sd card. Now it’s on its way to a warranty repair. Thanks again for the help. Happy trails
Marco
Thank you for the note, hope you are soon back on track.
Hallo geoW, little update, my old RaspberryPi was defective as well, I installed the Nextcloudpi software on an external HDD with 1TB Hooke it up to my new Pi an everything is working beautifully now.
Thanks again for the help and all the best wishes.
Thank you for reporting back, have much fun and enjoy reading the doks and forum posts. Good luck,
Georg
