Seems like you are not the only one
opened 05:31PM - 27 Jun 18 UTC
closed 12:49AM - 24 Sep 18 UTC
upstream
armbian
Thanks for reporting issues back to NextCloudPi!
Here you can file bug⦠s and feature requests
If there is an important security issue that has gone unnoticed, please send a private email to nacho _at_ ownyourbits.com
### QUESTIONS
Please, look at the FAQ before asking. https://github.com/nextcloud/nextcloudpi/wiki/FAQ
Also, make sure to read the articles in ownyourbits explaining NextCloudPi extras before asking. https://ownyourbits.com/category/nextcloudpi/
For asking questions, please use the forums. https://help.nextcloud.com/c/support/appliances-docker-snappy-vm
### PROBLEMS
If you are running into problems, please fill out the following information. For questions or feature requests you don't have to
Keep in mind that many problems come from faulty power sources and corrupted SD cards, so make sure this is not the case for you before reporting.
used the following to write image to sd card (example from the directions):
tar -xvf NextCloudPi-lite_02-12-17.tar.bz2
sudo dd bs=4M if=NextCloudPi-lite_02-12-17.img of=/dev/sdx
attempted twice with two different sd cards
I then used the following to try to build it:
git clone https://github.com/nextcloud/nextcloudpi.git
cd nextcloudpi
./build-SD-armbian.sh rock64
The build failed looking for docker tools.
Paste the output of `sudo ncp-report`
Good news, I was able to generate a good image, seems like the Armbian guys fixed their long standing issues.
https://ownyourbits.com/downloads/NextCloudPi_Rock64_09-23-18/
Please, somebody with a 4GiB version verify that this boots for them.
@nachoparker , Heading out on a business trip in the morning. Will be back later in the week and will give it a try. Was JUST getting ready to move over to the Rock64 from the RPi, so this is GREAT timing. Will let you know.
