Use embedded previews of ZIP-like files by juliushaertl Ā· Pull Request #20319 Ā· nextcloud/server Ā· GitHub previews for open document are enabled by default since 19 because no external tool is required to generate it.
ok, good to know, but is it normal that I get .pdf previews too?
And even if my config file contains:
āenabledPreviewProvidersā =>
0 => āOC\Preview\PNGā,
1 => āOC\Preview\JPEGā,
2 => āOC\Preview\GIFā,
Iād expect to get only images previews with this settings. Am I wrong?
Marco
Hello @ynjo,
this is an news article created by a bot.
Please open a new topic regarding your question.
Thank you.
EDIT:
hi @anon71540698,
did you find the option for āoptional automatic logoutā.
In the docs the only option mentioned are āauto_logoutā via the config.php file, in the GUI as far as I see there are no options.
No I didnāt.
My understanding is, this is in the same category as Talk v.9 client for Android - announced on June 3rd, still not availableā¦
Auto logout: https://github.com/nextcloud/server/pull/20298
I donāt think there is a gui option to enable it.
Hi! Iāve been waiting for Deck integration in Calendar. It was announced, but i can not find where i can enable it. Please help me find an instruction
Yep, you are not the only one, this would be great indeed.
According to this comment from @juliusknorr (thanks for your hard work) the server part is ready, but to make it usable, other areas have to get changes too. So at this moment you cannot use it yet, but an important step has been taken.
