NC12 Authentication issue with Cardav, Caldav and Sogo connector
The FIXME described above in those two files worked fine for me but I had to activate all NC calendars in Thunderbird one by one to have them displayed in Thunderbird.
THANKS A LOT !!!
Hi @nickvergessen,
thanks for your solution. Your solution worked perfect! I couldn’t add or reconnect within Thunderbird to my Calendars, because the System wouldn’t ask for Credentials. So after I implemented your Hack, it worked imediately.
Thanks again!
JamFx
Hi @nickvergessen
Update: it seems like it’s working atm, maybe because of caching or therelike the carddav sync didn’t respond to the quick fix immediately
Same problem with me. NC12 Authentication issue with Cardav, Caldav and Sogo connector worked as far as caldav sync is concerned.
Nevertheless I still cannot synchronize contacts using carddav. When starting a synchronization the synch job just will never finish. I had the same behavior with caldav before I used your mentionnen quick fixes.
I’m using the CardDav-Sync and CalDav-Sync apps on Android.
Same same - not different…
Ubuntu / Evolution
On my notebook I am working with Ubuntu and Evolution. Since migration from oc9 to nc12 synchronization of calendar and contacts is not possible.
Android / FolderSync
On my Android smartphone I have installed FolderSync. Seems that I have here the same authentification problem.
Hi all,
I am watching this thread because I have not yet upgraded to v12 as I absolutely cannot break cardDAV and calDAV support. If v12.0.1 fixes this, can one of you let us know?
Thanks
We’re aiming to include the following patch in 12.0.1 which should increase compatibility again.
It should be noted however, that this is an issue and bug in the DAV clients and not in Nextcloud itself.
thanks a lot @LukasReschke
I updated BearerAuth.php in accordance to your pull request and removed the fix from @nickvergessen. I can confirm that everything still works as it did before. :thumbsup:
hi,
if that is a bug in the dav-clients can you tell how and what can I send the developers, that they can fix that in most short time?
Thanks to @LukasReschke. And thanks to @MeCias for confirmation.
I updated my installation to use the daily build channel. When is the patch expected to show up?
Hi There,
Added proposed patch and Evolution working again.
Have you tried CardBook instead of Sogo Connector?
Hi all
I figured the exact same problem. Originally installed NC 12.0.0, then updated to NC 12.0.1, but was not able to connect to the CARDdav service with the URL mentioned in app contacts/settings, which is:
https://YOUR_DOMAIN:YOUR:PORT/remote.php/dav/addressbooks/users/YOUR_USERNAME/contacts/
Since I could successfully connect to my CALdav service, which shows a slightly different URL setup like this:
https://YOUR_DOMAIN:YOUR_PORT/remote.php/dav/principals/users/YOUR_USERNAME/
I tried that URL with my CARDdav service - and guess what? It works :slight_smile:
This should be the way to go:
  1. Create an app password
  2. Configure your carddav client to using a URL like the following:
  3. Use the username/password you setup in step 1.
  4. You should be good to go
And since user @cbrace asked for an info if 12.0.1 has a working caldav and carddav service:
At my site, with the “fix” mentioned above, both services successfully work.
Has the patch made it into 12.0.1? I updated but Thunderbird/SOGO is still asking for login/password at every startup.
I am still experiencing this issue with 12.0.2. I keep getting the following error in the Thundebird console.
09:40:38.908 [calCachedCalendar] replay action failed: null, uri=Domain.com Remote Session - Domain.com, result=2147500037, operation=[xpconnect wrapped calIOperation] 1 calCachedCalendar.js:330:29
I’m trying to determine if there is anything else.
EDIT: I deleted my /home/user/.thunderbird directory and the calendar functionality is working without a problem.
Did this bug make it into 11.0.5? I just updated my server yesterday from 11.0.4 to 11.0.5 (which is the latest in the stable channel). Yesterday, all clients were able to log in normally. Today, all of them repeatedly ask me to re-enter the account password. Clients are Thunderbird, the NextCloud client (on both a Windows and a Linux box) and Davdroid, an Android caldav app.
I tried creating an app specific password for the NextCloud client but that is not accepted either.
Other symptoms match the first post.
  • There are no errors logged in the logs seen in the NC admin interface.
  • Logins worked before the upgrade, but not after.
  • I can log into the NC web interface with the same password.
  • Calendar and Contacts display properly in the web UI.
I’ve searched through the forums & issues on github, but haven’t found anything referencing 11.0.x in regards to this.
Overall I have been mostly happy with NextCloud with the exception of a bug during migration from OwnCloud, where NC couldn’t update itself. This bug is frustrating, I hope there is a workaround or fix soon.
Hi. I’m using multi-instances Nextcloud. My instances release is 12.0.3 for nextcloud and 1.5.7 for calendar app.
For one of my instance, I’ve got this error for personnal calendar when I use my lightning extension (release 5.4.7):
replay action failed: null, uri=https://MYINSTANCE.TLD/remote.php/dav/calendars/MYUSER/personal/, result=2147500037, operation=[xpconnect wrapped calIOperation]
But, other instances work perfectly. Although, for the instance that give me this issue with Lightning, no problem with Evolution or cadaver.
Could someone give me his opinion about that?
Thanks.
No idea? Really?
@Ludogre Your issue looks like https://github.com/nextcloud/server/issues/10134
I’m closing this topic because it’s about a version of Nextcloud that’s end of life and there are more and more off-topic, general calendar / contacts posts in here.
If you have a question or need help setting up Calendar and Contacts, please open a new topic in https://help.nextcloud.com/c/apps/calendar respectively https://help.nextcloud.com/c/apps/contacts.
In case you have actual bug-reports, please check https://github.com/nextcloud/server/issues if it was already reported or open a new issue using the issue-template.
