Error: Undefined property: OCA\Onlyoffice\DocumentService::$logger at /var/www/nextcloud/apps/onlyoffice/lib/documentservice.php#435
/var/www/nextcloud/apps/onlyoffice/lib/documentservice.php - line 435:
OC\Log\ErrorHandler::onError()
/var/www/nextcloud/apps/onlyoffice/controller/settingscontroller.php - line 168:
OCA\Onlyoffice\DocumentService->checkDocServiceUrl()
/var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php - line 169:
OCA\Onlyoffice\Controller\SettingsController->SaveAddress()
/var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php - line 100:
/var/www/nextcloud/lib/private/AppFramework/App.php - line 152:
/var/www/nextcloud/lib/private/Route/Router.php - line 308:
OC\AppFramework\App::main()
/var/www/nextcloud/lib/base.php - line 1009:
OC\Route\Router->match()
/var/www/nextcloud/index.php - line 37:
OC::handleRequest()
Hi @earth,
did you move to Ubuntu 20 and NC 20 just now or already a while ago? To me it looks like the service URL is no longer ok. Did you check Config -> OnlyOffice -> Service address?
I installed it fresh on my rpi4 4gb.
I already double checked my service address.
with the above log this also comes same time
Exception: Call to a member function debug() on null
OC::handleRequest()
still no success on nextcloud20 with ubuntu 20.10 on raspberry pi 4 4gb
error
Error Exception: Call to a member function debug() on null
/var/www/nextcloud/lib/base.php - line 1008:
OC::handleRequest()
Caused by Error: Call to a member function debug() on null
OC::handleRequest()
Error Error: Undefined property: OCA\Onlyoffice\DocumentService::$logger at /var/www/nextcloud/apps/onlyoffice/lib/documentservice.php#435
OC::handleRequest()
Yesterday o got it working with apps available on AppStore.
With mobile edit. And also no qemu user which takes more of memory.
Please check it, if some body is eagerly waiting
I found this error in my error when live error is on
it constantly shows Error onlyoffice Group is unknown account
and my qemu.log shows
==== C stack trace ===============================
[0x0040038c2a92]
[0x00400437a390]
[0x0040048c5428]
[0x0040048c702a]
[0x0040049077ea]
[0x00400490780e]
[0x004004378875]
[0x0040043788d4]
[0x00400437897a]
[0x0040038c0480]
[0x0040038b5579]
[0x0040038b6a7b]
[0x0040038c15bf]
[0x0040043706ba]
[0x00400499741d]
[end of stack trace]
qemu: uncaught target signal 6 (Aborted) - core dumped
/opt/onlyoffice-wrapper/qemu-x86_64 -cpu max -d unimp,guest_errors -L /opt/onlyoffice-wrapper/qemu-x86-libs ./x2t.bin /tmp/oc_tmp_Umj2K2-.xml
The futex facility returned an unexpected error code.The futex facility returned an unexpected error code.Received signal qemu: uncaught target signal 6 (Aborted) - core dumped
/opt/onlyoffice-wrapper/qemu-x86_64 -cpu max -d unimp,guest_errors -L /opt/onlyoffice-wrapper/qemu-x86-libs ./x2t.bin /tmp/oc_tmp_18oXRY-.xml
The futex facility returned an unexpected error code.The futex facility returned an unexpected error code.Received signal Received signal 66
The futex facility returned an unexpected error code.qemu: uncaught target signal 6 (Aborted) - core dumped
/opt/onlyoffice-wrapper/qemu-x86_64 -cpu max -d unimp,guest_errors -L /opt/onlyoffice-wrapper/qemu-x86-libs ./x2t.bin /tmp/oc_tmp_JRM6VZ-.xml
The futex facility returned an unexpected error code.The futex facility returned an unexpected error code.qemu: uncaught target signal 6 (Aborted) - core dumped
/opt/onlyoffice-wrapper/qemu-x86_64 -cpu max -d unimp,guest_errors -L /opt/onlyoffice-wrapper/qemu-x86-libs ./x2t.bin /tmp/oc_tmp_Ay1gk0-.xml
I got it working in a docker container. Not as convenient as an app on Nextcloud, but I can guarantee that it works as of writing this. If you want to use larger files, I have a way and I’m trying to make a script that would work with docker compose, but I don’t really have free time and I don’t know this stuff.
Shortcomings: It takes time to build the docker image. Make a coffee, start the build and wait. Haven’t found anything not working so far, I’m using it every day and no issues so far.
Hi jiriks74,
great work. I just checked your repository and the docs. You really put a lot of effort in the development and the documentation.
I moved away from my little ARM device (2GB RAM only) and went back to an Intel-powered Herobox. That now serves Nextcloud + Adguard DNS in Docker containers for all other devices.
