okay i tried a couple more times, here’s where i’m at.
- proper reset
- on initial setup, restore backup
- after restore is done, before starting containers,
sudo mount -a
- run commands
sudo chown -R 33:0 /mnt/your-drive-mountpoint
andsudo chmod -R 750 /mnt/your-drive-mountpoint
- start containers
what i realized is that chown
and chmod
do not work unless i run the mount command again. if i skip step 3/4 and do not run those commands, i get the permissions error. if i run those commands and start the containers, i get the generic error message at the very beginning of this thread. i tried everything with my old fstab and the new one using the credentials in a separate file.
thanks for all your help so far, but is there anything else you can recommend? @szaimen
