I really can not remember what it was. It was only occuring on Ubuntu as well as I was ‘testing’ Ubuntu Server again. I moved on from it (everything just seemed slow to respond. Really did not get what I expected from it to the point using caching tech’s like APCU and Redis was pointless. And this was on multiple differant machines).
Sorry I cant be of much use. What I remember I can guarantee is not what the fix was.
@riegerCLOUD sorry for late answer but had to focus on other stuffs I’m still no luck with that and becoming crazy !!
I adjusted global PHP configuration for my apache and also the fcgid parameter like that but keep getting that error
Now the difference is that instead of getting a server error at end of upload I get a notification in Nextcloud about lost connection with server… and nothing anymore in error log of Apache
Update: found this in Nextcloud logs so it looks like it uses webdav process for upload of files but how do you setup ? found nothing in NextCloud
It seems to be an issue with the combination with mod_fcgid. I switched to php-fpm/mod_fastcgi and now it works like a charm. My php configuration is still untouched after this change…
Hi, I had the same issue, thanks for the help. I’ve change it in the .htaccess. Which size do you prefer for the max upload settings? What happening if you use nextcloud at home and want to save complete system backups on it? Do I need to increase the values up to 1TB or something like this?
EDIT: I am using a NGINX container to serve the SSL certificate. NGINX apparently has a default limit of just over 1MB. You must define a max size in your nginx.conf file if you want anything other than that.
I am using Docker on CentOS 7. I have mariadb, nextcloud, and nginx containers. I have checked the host for the php.ini file (all the container files are stored in /var/lib/docker/volumes/). And on the host, I only see /etc/php.ini I changed the lines:
After restarting all the containers, the Web Interface still only shows “2 MB”, and won’t save changes.
I also edited the following files as well and put 512M …
/var/lib/docker/volumes/nextcloud/_data/.user.ini
/var/lib/docker/volumes/nextcloud/_data/.htaccess
With no improvement… Still stuck on “2 MB”
And actually, anything over 1 MB hangs (so 1.1 MB hangs).
Hello, I’ve same issue with error message : 413 Request Entiry Too Large".
I change in /etc/php/7.0/apache2/php.ini & /var/www/nextcloud/.htaccess value for
post_max_size = 10240M
upload_max_filesize = 10240M
client_max_body_size 10240M;
I try with M or 1G.
Restarting Apache but still can’t upload files bigger than 1M.
Hi, I ask for help! The situation is absolutely return. It is impossible to limit the size of the loaded file. Via the browser the file any big file, despite restrictions 5M is loaded into php.ini, .htaccess, .user.ini. Files of a configuration are read out correctly. At a conclusion of phpinfo it is received:
PHP Version 5.6.35
Directive Local Value Master Value
default_charset UTF-8 UTF-8
file_uploads On On
memory_limit 512M 512M
post_max_size 5M 5M
upload_max_filesize 5M 5M
Changes are accepted and brought through the admin settings. I tried to make changes directly to the files php.ini, .htaccess, .user.ini. - nothing helps. On the same server the website works with Moodle - there all restrictions work correctly as it is specified in post_max_size, upload_max_filesize.
FreeBSD 11,1; Apache 2.4; Nextcloud 13.0.6; MySQL 5.6.39; PHP 5.6.35
Why on nextcloud doesn’t srabat_vat restriction of the size of files? Where to dig? It seems that I have checked everything… (The translation into English - Google so in advance I apologize for incorrectness)
make sure if you are changing in php -> apache -> php.ini you must have to change “memory_limit” and “post_max_size”
where memory_limit always be grater then post_max_size
memory_limit = 3G
post_max_size = 2G
and then restart Apache server.
and then go to nextcloud setting and change to max size and/or save.
The problem is that nextcloud does not react at all to the size limit in the php.ini directives memory_limit = 512M, post_max_size = 128M, and a file larger than 512M is easily loaded. On changes to these directives in the files nextcloud / .htaccess, .user.ini. also does not respond, any files are loaded, of any size. Apache after changes in php.ini rebooted, saved changes in the settings nextcloud, there is no other php.ini file on the server.
Has anyone actually gotten to the root-cause of this? I’m seeing any file > 2MB is unable to be uploaded. I’ve checked my php.ini settings and I’ve got:
upload_max_filesize = 10G
post_max_size = 10G
(as reported by phpinfo(), so I know this is active for the web server)
In nginx I’ve set:
and reloaded nginx though I’m unsure how to test it.
Finally in Nextcloud 16.0.1 I can confirm that Settings -> Monitoring, the PHP section shows a 1GB memory limit and 10G max upload size, so my 3MB files should be uploading just fine.
I looked in the www user’s ~/.user.ini and it doesn’t have any settings related to restricting file size. I tried hacking a few settings into there but none seemed to matter.
Never mind… I figured it out. I was running through a reverse proxy at my firewall and I didn’t have that proxy nginx configured to allow large transfers. SOLVED.
