I remain stumped. Unless I am missing somethingā¦ this didnāt make any difference (adding the localhost entries you mentioned and enabling with a2ensite).
Is there something more to the first part of your reply? āredirect all the ressources on the environment where the CODE docker is deployedā
Or do you just mean what you mentioned in the second part of your reply?
worked fine for me (after merging them with my own Letsencrypt SSL conf).
At some point I had the 404 error on /hosting/discovery because I forgot the mentioned lines.
Make sure you have thoroughly followed all the steps.
I am not expert enough in apache to troubleshoot specific errors. Any chance with the logs?
To add some input on this, I am now also stuck with the
ClientRequestHandler::handleRequest: BadRequestException: Invalid URI or access denied.
The reasons advanced here in this topic for this issue seem to be that separating the nextcloud and CODE environments to different subdomains through apache reverse proxying blocks some information transmission (socket?) between the two. A local build of CODE seems to work fine.
(The following does not work, this is just for the sake of the discussion)
I actually donāt like the idea to expose the whole CODE only for this purpose when I could directly contact the docker on the local network. Furthermore using this self-signed certificate system.
This said, fully deploying on local causes issues: Problem with Collabora Online nginx setup - #17 by lukas
For my test purpose I have deployed everything on my local but the way docker handles the ā-p 127.0.0.1:9980:9980ā seems to mess up with the https communication with nextcloud/owncloud if you configure the CODE address at āhttps://localhost:9980ā
A solution I could think about is to use dsndock (https://github.com/tonistiigi/dnsdock)
This allows you to consider all your dockers as machines in your domain with names in your dns.
After succesfully doing this I changed all my āhttps://localhost:9980ā to āhttps://code.docker:9980ā (default configuration)
The apache reverse proxy way still gives the same error.
Now if I try āhttps://code.docker:9980ā for CODE address in nextcloud itself I have the wonderful:
Collabora Online unknown error: cURL error 51: SSL: certificate subject name ālocalhostā does not match target host name ācode.dockerā
The Self-signed certificate provided in the docker seems unsafe to me and is even blocking in my case.
Any idea how to work around this?
Iāll have to try merging with my letsencrypt SSL configuration and digging through the logs - but that wonāt be able to happen too soon (full day).
(if you do it, please replace the code.docker by localhosts in the ProxyPasses)
(But remember that eventually after that, there is still this BadRequestException error happening)
<IfModule mod_ssl.c>
<VirtualHost *:443>
# The ServerName directive sets the request scheme, hostname and port that
# the server uses to identify itself. This is used when creating
# redirection URLs. In the context of virtual hosts, the ServerName
# specifies what hostname must appear in the request's Host: header to
# match this virtual host. For the default virtual host (this file) this
# value is not decisive as it is used as a last resort host regardless.
# However, you must set it for any further virtual host explicitly.
#ServerName www.example.com
ServerAdmin <admin-mail>
ServerName <domain>
ServerAlias <subdomain>
DocumentRoot /var/www/<domain>/public_html
# Available loglevels: trace8, ..., trace1, debug, info, notice, warn,
# error, crit, alert, emerg.
# It is also possible to configure the loglevel for particular
# modules, e.g.
#LogLevel info ssl:warn
# For most configuration files from conf-available/, which are
# enabled or disabled at a global level, it is possible to
# include a line for only one particular virtual host. For example the
# following line enables the CGI configuration for this host only
# after it has been globally disabled with "a2disconf".
#Include conf-available/serve-cgi-bin.conf
# Encoded slashes need to be allowed
AllowEncodedSlashes On
# Container uses a unique non-signed certificate
SSLProxyEngine On
SSLProxyVerify None
SSLProxyCheckPeerCN Off
SSLProxyCheckPeerName Off
# keep the host
ProxyPreserveHost On
# static html, js, images, etc. served from loolwsd
# loleaflet is the client part of LibreOffice Online
ProxyPass /loleaflet https://code.docker:9980/loleaflet retry=0
ProxyPassReverse /loleaflet https://code.docker:9980/loleaflet
# WOPI discovery URL
ProxyPass /hosting/discovery https://code.docker:9980/hosting/discovery retry=0
ProxyPassReverse /hosting/discovery https://code.docker:9980/hosting/discovery
# Main websocket
ProxyPass /lool/ws wss://code.docker:9980/lool/ws
# Admin Console websocket
ProxyPass /lool/adminws wss://code.docker:9980/lool/adminws
# Download as, Fullscreen presentation and Image upload operations
ProxyPass /lool https://code.docker:9980/lool
ProxyPassReverse /lool https://code.docker:9980/lool
SSLCertificateFile /etc/letsencrypt/live/<domain>/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/<domain>/privkey.pem
</VirtualHost>
# vim: syntax=apache ts=4 sw=4 sts=4 sr noet
</IfModule>
No I have everything entirely self hosted. Iāve almost got everything working correctly. Iām just coming across a few really weird issues. Collabora is able to open some documents. All types, ODF, DOC, DOCX, XLS, etcā¦ but it seems to decide all on its own to just stop working again. Itās totally random.
Thatās the only thing I didnāt have before. Still getting a 404 error, nothing in the logs seems to indicate any issue.
Still getting a 404ā¦ https://office.sptmin.com/hosting/discovery
Does anyone have any idea what to do? (something that will actually work )ā¦
<VirtualHost *:443>
ServerName office.sptmin.com:443
# SSL configuration, you may want to take the easy route instead and use Lets Encrypt!
SSLEngine on
SSLCertificateFile /etc/letsencrypt/live/office.sptmin.com/cert.pem
SSLCertificateChainFile /etc/letsencrypt/live/office.sptmin.com/chain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/office.sptmin.com/privkey.pem
SSLProtocol all -SSLv2 -SSLv3
SSLCipherSuite ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES128-SHA:ECDHE-RSA-AES256-SHA384:ECDHE-RSA-AES128-SHA:ECDHE-ECDSA-AES256-SHA384:ECDHE-ECDSA-AES256-SHA:ECDHE-RSA-AES256-SHA:DHE-RSA-AES128-SHA256:DHE-RSA-AES128-SHA:DHE-RSA-AES256-SHA256:DHE-RSA-AES256-SHA:ECDHE-ECDSA-DES-CBC3-SHA:ECDHE-RSA-DES-CBC3-SHA:EDH-RSA-DES-CBC3-SHA:AES128-GCM-SHA256:AES256-GCM-SHA384:AES128-SHA256:AES256-SHA256:AES128-SHA:AES256-SHA:DES-CBC3-SHA:!DSS
SSLHonorCipherOrder on
SSLProxyEngine On
SSLProxyVerify None
# keep the host
ProxyPass /loleaflet https://127.0.0.1:9980/loleaflet retry=0
ProxyPassReverse /loleaflet https://127.0.0.1:9980/loleaflet
ProxyPass /hosting/discovery https://127.0.0.1:9980/hosting/discovery retry=0
ProxyPassReverse /hosting/discovery https://127.0.0.1:9980/hosting/discovery
ProxyPass /hosting/discovery https://localhost:9980/hosting/discovery
ProxyPassReverse /hosting/discovery https://localhost:9980/hosting/discovery
# Main websocket
ProxyPass /lool/ws wss://127.0.0.1:9980/lool/ws
ProxyPass /lool/adminws wss://127.0.0.1:9980/lool/adminws
ProxyPass /lool https://127.0.0.1:9980/lool
ProxyPassReverse /lool https://127.0.0.1:9980/lool
</VirtualHost>
Tell me if I missed anythingā¦ (Iām beginning to feel like this is a well crafted practical joke).
Installed both NC 9.0.53 and NC 10beta following the instructions and tried to get Collabora working - to no avail.
I followed instructions for Collabora exactly: fired up the docker image (on a different host, but adjusted the docker commandline accordingly), configured Apache to proxy to the different host and had NC save the domain for the Collabora host.
Now, when I open the Office App in NC it displays the available ODT files as really large icons. Once I click one of them I get the rotating circle - but thatās it No content, no buttons I could push, ā¦ - plain nothing After a while the rotating circle vanishes, then I just have the NC bar at the top and a grey screen otherwise
Hi.
I have my Nextcloud installed on a local server and it is and will be only available in local network, therefore I donāt have a domain name and I canāt get SSL certificate. Is this somehow possible to install Collabora with that configuration?
Hello, I followed the official install guide as far as possible, but now Iām facing the following issue when trying to open a document:
āWe are sorry, this is an unexpected connection error. Please try again.ā
Here an error I found in the docker container while running: # docker logs 01ace1d79076
My current guess is that its an AUFS issue. But as Iām running it on a production server, I currently donāt dare to switch to debian testing which has a more recent kernel with built-in overlayfs support (part of mainline linux kernel which is not the case for AUFS. Many references also prefer overlayfs over AUFS). Anyone willing to give it a try?
