I updated my nextcloud instance to 27.1.2 today and also got this message. Iâm running nextcloud with nginx and my nginx config doesnât contain any âocm-providerâ. My .htacces file looks like KittyMeow stated.
My solution:
RewriteRule ^ocm-provider/?$ /index.php [QSA,L] changed to
RewriteRule ^ocm-provider/?$ /nextcloud/index.php [QSA,L]
My instance placed in a subfolder (https://example.com/nextcloud/)
Ok, seems like this is tracked as a bug: https://github.com/nextcloud/server/issues/40803
I will wait for a solutionâŚ
Nginx does not make use of .htaccess files, so you have to edit it by hand anyway. If you have chosen for nginx as webserver, you should read the manual if anything had changed after each update and change it yourselfâŚ
â Old config (highlight=oc[ms]-provider) â
â New config (highlight=ocs-provider) â
In detail:
Search for this re-string:
oc[ms]-provider
in your nginx configfile and replace it by this string:
ocs-provider
reload or restart nginx
That should do it for you (and nginx users in general)
much luck!
Nope, I found and replaced the âoc[ms]-providerâ with âocs-providerâ, restarted nginx, but the message still appears.
Seems like I had some other issues in my nginx config. I replaced some sections from the new sample and now the message is gone. Thanks for the links @ernolf
That wasnât fixing my problem at all.
So currently my webserver is behind an nginx proxy manager, who redirect to my proxmox-container.
This one works with apache and âonlyâ http (Port 80). SSL is done by NPM, so no worry.
If I try all the fixes here, nothing works. Fact is, that going to wolke.mydomain.net/index.php/ocm-provider give me the needed result. But RewriteRules for wolke.mydomain.net/ocm-provider still not work. As you see, I use a subdomain for my cloud, what worked fine with 27.1.1 so far
My current .htaccess as code.
<IfModule mod_headers.c>
<IfModule mod_setenvif.c>
<IfModule mod_fcgid.c>
SetEnvIfNoCase ^Authorization$ "(.+)" XAUTHORIZATION=$1
RequestHeader set XAuthorization %{XAUTHORIZATION}e env=XAUTHORIZATION
</IfModule>
<IfModule mod_proxy_fcgi.c>
SetEnvIfNoCase Authorization "(.+)" HTTP_AUTHORIZATION=$1
</IfModule>
<IfModule mod_lsapi.c>
</IfModule>
</IfModule>
<IfModule mod_env.c>
# Add security and privacy related headers
# Avoid doubled headers by unsetting headers in "onsuccess" table,
# then add headers to "always" table: https://github.com/nextcloud/server/pull/19002
Header onsuccess unset Referrer-Policy
Header always set Referrer-Policy "no-referrer"
Header onsuccess unset X-Content-Type-Options
Header always set X-Content-Type-Options "nosniff"
Header onsuccess unset X-Frame-Options
Header always set X-Frame-Options "SAMEORIGIN"
Header onsuccess unset X-Permitted-Cross-Domain-Policies
Header always set X-Permitted-Cross-Domain-Policies "none"
Header onsuccess unset X-Robots-Tag
Header always set X-Robots-Tag "noindex, nofollow"
Header onsuccess unset X-XSS-Protection
Header always set X-XSS-Protection "1; mode=block"
SetEnv modHeadersAvailable true
</IfModule>
# Add cache control for static resources
<FilesMatch "\.(css|js|mjs|svg|gif|png|jpg|ico|wasm|tflite)$">
<If "%{QUERY_STRING} =~ /(^|&)v=/">
Header set Cache-Control "max-age=15778463, immutable"
</If>
<Else>
Header set Cache-Control "max-age=15778463"
</Else>
</FilesMatch>
# Let browsers cache WOFF files for a week
<FilesMatch "\.woff2?$">
Header set Cache-Control "max-age=604800"
</FilesMatch>
</IfModule>
<IfModule mod_php.c>
php_value mbstring.func_overload 0
php_value default_charset 'UTF-8'
php_value output_buffering 0
SetEnv htaccessWorking true
</IfModule>
</IfModule>
<IfModule mod_mime.c>
AddType image/svg+xml svg svgz
AddType application/wasm wasm
AddEncoding gzip svgz
# Serve ESM javascript files (.mjs) with correct mime type
AddType text/javascript js mjs
</IfModule>
<IfModule mod_dir.c>
DirectoryIndex index.php index.html
</IfModule>
<IfModule pagespeed_module>
ModPagespeed Off
</IfModule>
<IfModule mod_rewrite.c>
RewriteEngine on
RewriteCond %{HTTP_USER_AGENT} DavClnt
RewriteRule ^$ /remote.php/webdav/ [L,R=302]
RewriteRule .* - [env=HTTP_AUTHORIZATION:%{HTTP:Authorization}]
RewriteRule ^\.well-known/carddav /remote.php/dav/ [R=301,L]
RewriteRule ^\.well-known/caldav /remote.php/dav/ [R=301,L]
RewriteRule ^remote/(.*) remote.php [QSA,L]
RewriteRule ^(?:build|tests|config|lib|3rdparty|templates)/.* - [R=404,L]
RewriteRule ^\.well-known/(?!acme-challenge|pki-validation) /index.php [QSA,L]
RewriteRule ^(?:\.(?!well-known)|autotest|occ|issue|indie|db_|console).* - [R=404,L]
</IfModule>
AddDefaultCharset utf-8
Options -Indexes
#### DO NOT CHANGE ANYTHING ABOVE THIS LINE ####
ErrorDocument 403 /index.php/error/403
ErrorDocument 404 /index.php/error/404
Options -MultiViews
RewriteRule ^core/js/oc.js$ index.php [PT,E=PATH_INFO:$1]
RewriteRule ^core/preview.png$ index.php [PT,E=PATH_INFO:$1]
RewriteCond %{REQUEST_FILENAME} !\.(css|js|mjs|svg|gif|png|html|ttf|woff2?|ico|jpg|jpeg|map|webm|mp4|mp3|ogg|wav|wasm|tflite)$
RewriteCond %{REQUEST_FILENAME} !/core/ajax/update\.php
RewriteCond %{REQUEST_FILENAME} !/core/img/(favicon\.ico|manifest\.json)$
RewriteCond %{REQUEST_FILENAME} !/(cron|public|remote|status)\.php
RewriteCond %{REQUEST_FILENAME} !/ocs/v(1|2)\.php
RewriteCond %{REQUEST_FILENAME} !/robots\.txt
RewriteCond %{REQUEST_FILENAME} !/(ocs-provider|updater)/
RewriteCond %{REQUEST_URI} !^/\.well-known/(acme-challenge|pki-validation)/.*
RewriteCond %{REQUEST_FILENAME} !/richdocumentscode(_arm64)?/proxy.php$
RewriteRule . index.php [PT,E=PATH_INFO:$1]
RewriteBase /
SetEnv front_controller_active true
DirectorySlash off
</IfModule>
</IfModule>
</IfModule>
My cloud is not working in a subdir for apache, cause the default-folder is /var/www/nextcloud as root-folder. So where is the missing point for me?
Look into your apache config for this entry:
<Directory /var/www/nextcloud>
Options Indexes FollowSymLinks
AllowOverride All
Require all granted
and change it from none to All that works for me.
Nothing fixed my problem.
My nextcloud is hosted under: nextcloud.mydomain.de
My .htaccess:
RewriteEngine on
</IfModule>
My apache config:
<VirtualHost *:80>
ServerName nextcloud.mydomain.de
Redirect / https://nextcloud.mydomain.de
ServerAdmin
DocumentRoot /var/www/nextcloud/
ErrorLog ${APACHE_LOG_DIR}/hostname.tld_error.log
CustomLog ${APACHE_LOG_DIR}/hostname.tld_access.log combined
Options Indexes FollowSymLinks MultiViews
AllowOverride All
Require all granted
<IfModule mod_dav.c>
Dav off
</IfModule>
</Directory>
</VirtualHost>
If I call âhttps://nextcloud.mydomain.de/index.php/ocm-provider/â I get a result/JSON FIle
Content from Setup.php:
$content .= "\n RewriteCond %{REQUEST_FILENAME} !/(ocs-provider|updater)/";
Hat nun endlich auch bei mir geklappt, danke!
