This solved the problem on my nextcloud 21.0.3 too. THANK YOU!
Work for me.
THX
Wholy sh…
this worked for me too.
THANKS
I had the issue on a fresh manual install !
Resolving @bb77 solved my problem in nextcloud 23.0.0.
THX!
where exactly you add the apc.enable_cli=1 ???
with file??
i have php 7.3
no file apcu.ini on /etc/php/7.3/mods-available/
i use nextcloud on docker…
this work for me ![]()
