Can't access nextcloud after setting up redis
What are the echoes of
redis-server --version
grep -v '^\s*$\|^\s*#' /etc/redis/redis.conf
tail -n 50 $(awk '/logfile/ {print $NF}' /etc/redis/redis.conf)
Which PHP SAPI speaks to your Apache2?
Find out with this query:
sudo apachectl -tD DUMP_INCLUDES 2>/dev/null | grep -v sites | sed -n '/php.*conf/ s#.*/\([^/]*\)\.conf#\1#p'
What is the echo of
grep -r "redis" /etc/php
With this information it should be easy to find the cause of your problem.
Much luck,
ernolf
Thank you for your reply @ernolf. Please find my response below.
redis-server -v 6.0.16
grep -v '^\s*$\|^\s*#' /etc/redis/redis.conf echos
bind 127.0.0.1 ::1
protected-mode yes
port 0
tcp-backlog 511
unixsocket /var/run/redis/redis-server.sock
unixsocketperm 770
timeout 0
tcp-keepalive 300
daemonize yes
supervised no
pidfile /var/run/redis/redis-server.pid
loglevel notice
logfile /var/log/redis/redis-server.log
databases 16
always-show-logo yes
save 900 1
save 300 10
save 60 10000
stop-writes-on-bgsave-error yes
rdbcompression yes
rdbchecksum yes
dbfilename dump.rdb
rdb-del-sync-files no
dir /var/lib/redis
replica-serve-stale-data yes
replica-read-only yes
repl-diskless-sync no
repl-diskless-sync-delay 5
repl-diskless-load disabled
repl-disable-tcp-nodelay no
replica-priority 100
acllog-max-len 128
maxclients 512
lazyfree-lazy-eviction no
lazyfree-lazy-expire no
lazyfree-lazy-server-del no
replica-lazy-flush no
lazyfree-lazy-user-del no
oom-score-adj no
oom-score-adj-values 0 200 800
appendonly no
appendfilename "appendonly.aof"
appendfsync everysec
no-appendfsync-on-rewrite no
auto-aof-rewrite-percentage 100
auto-aof-rewrite-min-size 64mb
aof-load-truncated yes
aof-use-rdb-preamble yes
lua-time-limit 5000
slowlog-log-slower-than 10000
slowlog-max-len 128
latency-monitor-threshold 0
notify-keyspace-events ""
hash-max-ziplist-entries 512
hash-max-ziplist-value 64
list-max-ziplist-size -2
list-compress-depth 0
set-max-intset-entries 512
zset-max-ziplist-entries 128
zset-max-ziplist-value 64
hll-sparse-max-bytes 3000
stream-node-max-bytes 4096
stream-node-max-entries 100
activerehashing yes
client-output-buffer-limit normal 0 0 0
client-output-buffer-limit replica 256mb 64mb 60
client-output-buffer-limit pubsub 32mb 8mb 60
hz 10
dynamic-hz yes
aof-rewrite-incremental-fsync yes
rdb-save-incremental-fsync yes
jemalloc-bg-thread yes
The tail of /etc/redis/redis.conf) echos awk: fatal: cannot open file `/etc/redis/redis.conf' for reading: Permission denied. It’s the same message with and without sudo privileges. For what it’s worth, the final 10 lines of the redis config file are all commented out.
sudo apachectl -tD DUMP_INCLUDES 2>/dev/null | grep -v sites | sed -n '/php.*conf/ s#.*/\([^/]*\)\.conf#\1#p' That echos php8.1-fpm as I’d expect.
Last, but not least, your final echo request returns /etc/php/8.1/mods-available/redis.ini:extension=redis.so.
I’m certainly no expert in this, but most of that seems to be the results that I expected. The only odd result to me is the permission denied. I don’t know if it’s worth anything, but /etc/redis is owned by root with 755 permissions and /etc/redis/redis.conf is owned by redis with 640 permissions. The latter of which seem a bit odd to me. Then again, the only thing I know about redis is from the NC documentation.
Thanks for the assistance thus far.
Out of annoyance and some frustration, I deleted my NC and data folders and started again. I even copied the exact same config.php file that I’d copied previously (which came from an older successful install) for the above referenced install and changed all the relevant information. I even compared the two side by side and I couldn’t figure out what the difference was between them. I’m honestly at a loss to understand why it didn’t work the first time and does now.
This is (was) the cause of your issue:
That way your redis server will never start by the systemd mechanism.
It should be
supervised auto
or simply be commented out, since that is the default.
I did not ask for the tail of /etc/redis/redis.conf. I asked for the echo of
wich is the tail of the last 50 lines of the result of
in other words, it should give the last 50 lines of the file /var/log/redis/redis-server.log
It is very strange, that awk can not read /etc/redis/redis.conf while grep can :thinking:
YOU expected it, I did not know that and you did not provide that information in your post while it is an important info!
So you did not add the redis config to your /etc/php/8.1/cli/php.ini and /etc/php/8.1/fpm/php.ini:
redis.session.locking_enabled = 1
redis.session.lock_retries = -1
redis.session.lock_wait_time = 10000
OK, On all of my instances, /etc/redis is owned by redis and /etc/redis/redis.conf has 644 permission.
:woozy_face:
Much luck,
ernolf
Thank you. I’d not noticed that, but it makes sense.
Agreed. I tried searching for a little while and could not come up with much.
Whoa, sorry. As I was responding to an existing topic, I was not aware of what “important” info someone else might want.
Yes, you are correct and was a mistake that I made. Which, I ended up discovering later when I set 'memcache.local' => '\\OC\\Memcache\\APCu', and couldn’t get it to work either.
Thank you, this is helpful to know.
Thank you for your detailed assistance.
