Can you run
sudo find / -name docker.sock
and post the output here?
Can you run
$ sudo find / -name docker.sock
/run/docker.sock
/run/user/1000/docker.sock
/home/ubuntu/.local/share/docker/vfs/dir/6edad21a876d359d2a79d0668a886a0576161dcf118d0c503e99c38c6e4da3b8/run/docker.sock
Found it. So apparently what I wrote is indeed the case
/run/docker.sock is the normal docker socket
/run/user/1000/docker.sock is the rootless docker socket
that’s really odd… I’m starting to think this has to do with lxd… I’ve never had this coming up before. I’ll look into it and try to understand whats going on.
Thanks for taking the time to help me out!
So I digged a bit more into this and I suspect what happened was I initially forgot to turn on nested virtualization on the LXD container for nextcloud, before installing docker.
As I recreated a new LXD container with nested virt before hand, after installing docker inside it, I now get:
Client: Docker Engine - Community
Version: 24.0.2
**Context: default**
Debug Mode: false
Plugins:
buildx: Docker Buildx (Docker Inc.)
Version: v0.10.5
Path: /usr/libexec/docker/cli-plugins/docker-buildx
compose: Docker Compose (Docker Inc.)
Version: v2.18.1
Path: /usr/libexec/docker/cli-plugins/docker-compose
I’m now going to install nextcloud aio container.
EDIT: all working! Thanks again!
