Zugang über WebDav geht nur wenn vorher Net use ausgeführt wurde
example
longer
example
here
Nextcloud version (eg, 12.0.2): 16.04
Operating system and version (eg, Ubuntu 17.04): Ubuntu 18.04
Apache or nginx version (eg, Apache 2.4.25): Apache/2.4.29
PHP version (eg, 7.1): 7.2.19
  1. open windows Explorer and add a Network location
  2. add url like “https://server.local.com/remote.php/webdav/
  3. Error occurs “The entered folder is invalid…”
  4. open CMD and type “net use * https://server.local.com/remote.php/webdav/” with userID and passord.
    After step 4 and enter userID and pwd i can map a network drive and step 1 and 2 are working also after step. 4.
    I trie that on windows 10, 2012 and 2016, all the same result
We using cert from lets Encrypt.
Is there any on how can help?
Thanks in advanced
TBC
Try this:
net use z: https://your.domain.com/remote.php/dav/files/yourusername/ /persistent:yes /user:username password
maybe you wanna try \\yournextcloud@SSL\DavWWWRoot\remote.php\dav\files\username instead?
and if it’s only about connecting a network drive to your nc you could use raidrive (for free)
btw: it would be helpful if you would have given out info about the windows-version you run
Thank you both,
i have now installed the letest NC Version. I have checked you both post an both are right but the connection to NC WevDav is only available if i using Net use first. After Net Use every Thing is perfekt.
@Jimmy Kater, wat is raidrive?
google is your friend… and would get you to raidrive.com
