example
longer
example
here
Files in downloaded and unzipped Folders are empty (0B).
This only happens on my Phone (Android). On my PC it works perfectly fine.
Is there another way to save Images to the gallery, since it’s not a feature in the app?
- Go to your Next loud page
- Download a folder
- Unzip it
