Wrong storage showing
i have about 30gb of files on my nextcloud sever yet the storage icon in the bottom left says only 16mb have been used
Follow the support template. You would have better luck on github for this anyway as it’s a technical issue.
Are your storage mounted?
Are your files located in the Nextcloud data folder?
Are you getting any errors in the log?
You need to give more information about your problem, system and config etc.
