Write rights for a shared subfolder when a folder has read-only rights
Hey all. Please, help to configure the write access rights to a subfolder, which is a part of the folder which is shared with read-only rights in order a user can add files there and modify existing files there.
So, there is a group folder A, which is shared with RO access rights with userA. There are other subfolders there, in particulat folderA/subfolderAA, which are consequently shared as RO. I would like to make it shared with write/modify access rights.
Just setting it manually with modify access rights doesn’t produce any effect.
How to achieve this goal?
You must configure that with the → Advanced Permissions ← Feature.
Similar question:
Much and good luck,
ernolf
