Hello.
On my old server I had nextcloud with docker and Portainer to build the stack.
In the text below I showing my docker-compose file, it was a copy/paste from some website and I wasn’t aware that the database volume was in a relative path ./db:/var/lib/mysql
How can I recover the database? I can’t find it for any volume
version: '2'
services:
db:
image: mariadb:10.5.11
restart: always
volumes:
- ./db:/var/lib/mysql
environment:
- MYSQL_ROOT_PASSWORD="foo"
- MYSQL_PASSWORD="bar"
- MYSQL_DATABASE=nextcloud
- MYSQL_USER=nextcloud
nextcloud:
image: iamklaus/nextcloud
restart: always
container_name: nextcloud_nextcloud_1
hostname: mynextcloud.es
ports:
- "8001:80"
- "8443:443"
links:
- db
volumes:
- /docker/nextcloud/config:/var/www/html/config
- /docker/nextcloud/data:/var/www/html/data
- /docker/nextcloud/custom_apps:/var/www/html/custom_apps
- /docker/nextcloud/themes:/var/www/html/themes
environment:
- MYSQL_HOST=db
- PHP_MEMORY_LIMIT=8G
volumes:
nextcloud:
db:
