Nextcloud version 18.0.2
Operating system and version Ubuntu 18.04
Apache or nginx version Apache 2.4.29
PHP version _7.2.24
Is this the first time you’ve seen this error? (Y):
When sharing a folder with a public link
- log in with a valid user
- share a folder that contains sub-folders
- goto the shared link from any device.
when doing this the folder icons are all gray and not showing the same as it does when logged in with a valid user
** you can see a screenshoot here: https://www.screencast.com/t/7k7UBt2UZ
Not sure what to look at in the log
'instanceid' => '********',
'passwordsalt' => '********',
'secret' => '********',
0 => '********',
1 => '********',
2 => '********',
'datadirectory' => '/********/data',
'version' => '18.0.2.2',
'overwrite.cli.url' => 'https://********.********',
'dbname' => '********',
'dbhost' => '********',
'dbtableprefix' => '********_',
'dbuser' => '********',
'dbpassword' => '********',
'redis' =>
'host' => 'localhost',
'port' => 6379,
'timeout' => 3,
'mail_from_address' => '********',
'mail_smtpmode' => 'smtp',
'mail_domain' => '********',
'mail_smtpauthtype' => 'NTLM',
'mail_smtphost' => '********',
'mail_smtpport' => '********',
'app_install_overwrite' =>
0 => 'sharerenamer',
PASTE HERE
**** Please let me know what else I need to add to this to get help with the investigation ****
