As the the title asks, I am wondering what’s the difference between fields deleted
and trashed
on objects passwords_entity_folder_revision
, passwords_entity_tag_revision
and passwords_entity_password_revision
and trashed
The trashed
attribute will be set to true
if the user decides to delete an object. These objects will not be shown in any regular list
or find
command unless it is specifically requested. These objects are in the system trash and can be restored via the restore
command.
If the user decides to delete an object that is in the system trash, it will be marked as deleted
. These objects can no longer be accessed via the api. These objects will also be permanently deleted from the database if the wait time defined by the administrator is reached.
You can find more information in the developer manual.
