I’m trying to load a client list consisting of id and name into a . I followed the app development tutorial to solve it with consintent code. As first step I added routes, controllers, mappers and services basically more copy and paste. Then I added a template in the part.content.php and created a short JS script based on the script in the tutorial. To keep it simple via testing for myself I started just getting the items as a simple list but nothing is displayed. Any help in solving this is aprecciated.
Here when running everything with the following code I truly get nothing but the things I already have . . . nor an error message in the logs or console.
HTML
{{#each clients}} <li class="client" data-id="{{ id }}"> <p>{{ name }}</p> </li> {{/each}}
JS
(function (OC, window, $, undefined) { 'use strict'; $(document).ready(function () { // this clients object holds all our clients var Clients = function (baseUrl) { this._baseUrl = baseUrl; this._clients = []; this._activeClient = undefined; }; Clients.prototype = { getAll: function () { return this._clients; }, loadAll: function () { var deferred = $.Deferred(); var self = this; $.get(this._baseUrl).done(function (clients) { self._activeClient = undefined; self._clients = clients; deferred.resolve(); }).fail(function () { deferred.reject(); }); return deferred.promise(); } }; // this will be the view that is used to update the html var View = function (clients) { this._clients = clients; }; View.prototype = { renderClients: function () { var source = $('#content-tpl').html(); var template = Handlebars.compile(source); var html = template({clients: this._clients.getAll()}); $('#editor').html(html); var entry = $(this).closest('.client'); }, render: function () { this.renderClients(); } }; var clients = new Clients(OC.generateUrl('/apps/ownclients/clients')); var view = new View(clients); clients.loadAll().done(function () { view.render(); }).fail(function () { alert('Could not load clients'); }); }); })(OC, window, jQuery);
Thanks!
Andy
