I’m getting slow uploads ~10MB/s with peaks of 20MB/s via the web UI.
Uploads via webdavs ~200MB/s average with 300MB/s burst.
Downloads via WebUI ~100MB/s
Webdav uploads fail when they are several GB in size, despite php having the correct settings for 20GB+ files.
Currently using Apache2 with PHP-FPM 7.3. 512MB PHP memory.
Is your php running out of CPU?
I use HTTP/2 with php-fpm. Fpm is a lot faster than standard php in cgi mode.
<VirtualHost *:443>
Protocols h2 h2c http/1.1
H2EarlyHints on
ServerName xxxx.xxx
# ServerAlias
...logging, paths etc
Header append Vary: Accept-Encoding
Header always set Strict-Transport-Security "max-age=31536000; includeSubDomains; preload"
SetEnv HOME "/var/www/domains/xxxxxxx/htdocs/nextcloud"
SetEnv HTTP_HOME "/var/www/domains/xxxxx/htdocs/nextcloud"
<FilesMatch \\.php$>
SetHandler "proxy:unix:/run/php-fpm/php-fpm.socket|fcgi://localhost"
</FilesMatch>
SSLCertificateFile /etc/letsencrypt/live/xxxxxxxxx/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/xxxxxxxxx/privkey.pem
I mean, even with fpm7.3 it’s still slow.
CPU on overall php threads combined is ~20% of a core tops. MySQL is using more CPU (30% of a core) when uploading thousands of files with webdav.
I only have the h2 protocol enabled, but that shouldn’t be hindering performance.
