WebSocket no connection
i have a strange situation, that the websocket is not working.
I access the webpage direcly via an A-Record and via domain name.
The Nextcloud instance is working fine.
Error in Console log:
WebSocket connection to ‘wss://nextcloud.url.com/push/ws’ failed:
What do I have to set on my apache2 configuration (its a RHEL machine)
What do I can do to verify if all is proper set up.
Are you using notify_push?
If so, follow the web server and proxy configuration instructions located at the link above.
