Nextcloud logs
{"reqId":"ZDaFAkBU82BuUFWLqqZQeQAAUxc","level":2,"time":"2023-04-12T10:17:00+00:00","remoteAddr":"188.174.53.129","user":"--","app":"core","method":"GET","url":"/index.php/apps/notify_push/uid","message":"Login failed: 'xxx' (Remote IP: '188.174.53.129')","userAgent":"--","version":"25.0.5.1","data":{"app":"core"}}
{"reqId":"ZDaGy0BU82BuUFWLqqZQegAATxQ","level":3,"time":"2023-04-12T10:24:11+00:00","remoteAddr":"192.168.xxx.xx","user":"xxx","app":"PHP","method":"GET","url":"/index.php/settings/apps","message":"fwrite(): Unable to create temporary file, Check permissions in temporary files directory. at /var/www/nextcloud/3rdparty/guzzlehttp/psr7/src/Stream.php#254","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:109.0) Gecko/20100101 Firefox/112.0","version":"25.0.5.1","exception":{"Exception":"Error","Message":"fwrite(): Unable to create temporary file, Check permissions in temporary files directory. at /var/www/nextcloud/3rdparty/guzzlehttp/psr7/src/Stream.php#254","Code":0,"Trace":[{"function":"onError","class":"OC\\Log\\ErrorHandler","type":"::"},{"file":"/var/www/nextcloud/3rdparty/guzzlehttp/psr7/src/Stream.php","line":254,"function":"fwrite"},{"file":"/var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/Handler/CurlFactory.php","line":412,"function":"write","class":"GuzzleHttp\\Psr7\\Stream","type":"->"},{"function":"GuzzleHttp\\Handler\\{closure}","class":"GuzzleHttp\\Handler\\CurlFactory","type":"::","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/Handler/CurlHandler.php","line":44,"function":"curl_exec"},{"file":"/var/www/nextcloud/lib/private/Http/Client/DnsPinMiddleware.php","line":146,"function":"__invoke","class":"GuzzleHttp\\Handler\\CurlHandler","type":"->"},{"file":"/var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/PrepareBodyMiddleware.php","line":35,"function":"OC\\Http\\Client\\{closure}","class":"OC\\Http\\Client\\DnsPinMiddleware","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/Middleware.php","line":31,"function":"__invoke","class":"GuzzleHttp\\PrepareBodyMiddleware","type":"->"},{"file":"/var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/RedirectMiddleware.php","line":71,"function":"GuzzleHttp\\{closure}","class":"GuzzleHttp\\Middleware","type":"::","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/Middleware.php","line":63,"function":"__invoke","class":"GuzzleHttp\\RedirectMiddleware","type":"->"},{"file":"/var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/HandlerStack.php","line":75,"function":"GuzzleHttp\\{closure}","class":"GuzzleHttp\\Middleware","type":"::","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/Client.php","line":331,"function":"__invoke","class":"GuzzleHttp\\HandlerStack","type":"->"},{"file":"/var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/Client.php","line":168,"function":"transfer","class":"GuzzleHttp\\Client","type":"->"},{"file":"/var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/Client.php","line":187,"function":"requestAsync","class":"GuzzleHttp\\Client","type":"->"},{"file":"/var/www/nextcloud/lib/private/Http/Client/Client.php","line":218,"function":"request","class":"GuzzleHttp\\Client","type":"->"},{"file":"/var/www/nextcloud/lib/private/App/AppStore/Fetcher/Fetcher.php","line":120,"function":"get","class":"OC\\Http\\Client\\Client","type":"->"},{"file":"/var/www/nextcloud/lib/private/App/AppStore/Fetcher/AppFetcher.php","line":87,"function":"fetch","class":"OC\\App\\AppStore\\Fetcher\\Fetcher","type":"->"},{"file":"/var/www/nextcloud/lib/private/App/AppStore/Fetcher/Fetcher.php","line":192,"function":"fetch","class":"OC\\App\\AppStore\\Fetcher\\AppFetcher","type":"->"},{"file":"/var/www/nextcloud/lib/private/App/AppStore/Fetcher/AppFetcher.php","line":188,"function":"get","class":"OC\\App\\AppStore\\Fetcher\\Fetcher","type":"->"},{"file":"/var/www/nextcloud/lib/private/Installer.php","line":421,"function":"get","class":"OC\\App\\AppStore\\Fetcher\\AppFetcher","type":"->"},{"file":"/var/www/nextcloud/apps/settings/lib/Controller/AppSettingsController.php","line":151,"function":"isUpdateAvailable","class":"OC\\Installer","type":"->"},{"file":"/var/www/nextcloud/apps/settings/lib/Controller/AppSettingsController.php","line":134,"function":"getAppsWithUpdates","class":"OCA\\Settings\\Controller\\AppSettingsController","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","line":225,"function":"viewApps","class":"OCA\\Settings\\Controller\\AppSettingsController","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","line":133,"function":"executeController","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/App.php","line":172,"function":"dispatch","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/var/www/nextcloud/lib/private/Route/Router.php","line":298,"function":"main","class":"OC\\AppFramework\\App","type":"::"},{"file":"/var/www/nextcloud/lib/base.php","line":1047,"function":"match","class":"OC\\Route\\Router","type":"->"},{"file":"/var/www/nextcloud/index.php","line":36,"function":"handleRequest","class":"OC","type":"::"}],"File":"/var/www/nextcloud/lib/private/Log/ErrorHandler.php","Line":92,"CustomMessage":"--"}}
{"reqId":"ZDaGy0BU82BuUFWLqqZQegAATxQ","level":2,"time":"2023-04-12T10:24:11+00:00","remoteAddr":"192.168.xxx.xx","user":"xxx","app":"appstoreFetcher","method":"GET","url":"/index.php/settings/apps","message":"cURL error 23: Failure writing output to destination (see https://curl.haxx.se/libcurl/c/libcurl-errors.html) for https://apps.nextcloud.com/api/v1/apps.json","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:109.0) Gecko/20100101 Firefox/112.0","version":"25.0.5.1","exception":{"Exception":"GuzzleHttp\\Exception\\RequestException","Message":"cURL error 23: Failure writing output to destination (see https://curl.haxx.se/libcurl/c/libcurl-errors.html) for https://apps.nextcloud.com/api/v1/apps.json","Code":200,"Trace":[{"file":"/var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/Handler/CurlFactory.php","line":158,"function":"createRejection","class":"GuzzleHttp\\Handler\\CurlFactory","type":"::"},{"file":"/var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/Handler/CurlFactory.php","line":110,"function":"finishError","class":"GuzzleHttp\\Handler\\CurlFactory","type":"::"},{"file":"/var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/Handler/CurlHandler.php","line":47,"function":"finish","class":"GuzzleHttp\\Handler\\CurlFactory","type":"::"},{"file":"/var/www/nextcloud/lib/private/Http/Client/DnsPinMiddleware.php","line":146,"function":"__invoke","class":"GuzzleHttp\\Handler\\CurlHandler","type":"->"},{"file":"/var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/PrepareBodyMiddleware.php","line":35,"function":"OC\\Http\\Client\\{closure}","class":"OC\\Http\\Client\\DnsPinMiddleware","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/Middleware.php","line":31,"function":"__invoke","class":"GuzzleHttp\\PrepareBodyMiddleware","type":"->"},{"file":"/var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/RedirectMiddleware.php","line":71,"function":"GuzzleHttp\\{closure}","class":"GuzzleHttp\\Middleware","type":"::","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/Middleware.php","line":63,"function":"__invoke","class":"GuzzleHttp\\RedirectMiddleware","type":"->"},{"file":"/var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/HandlerStack.php","line":75,"function":"GuzzleHttp\\{closure}","class":"GuzzleHttp\\Middleware","type":"::","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/Client.php","line":331,"function":"__invoke","class":"GuzzleHttp\\HandlerStack","type":"->"},{"file":"/var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/Client.php","line":168,"function":"transfer","class":"GuzzleHttp\\Client","type":"->"},{"file":"/var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/Client.php","line":187,"function":"requestAsync","class":"GuzzleHttp\\Client","type":"->"},{"file":"/var/www/nextcloud/lib/private/Http/Client/Client.php","line":218,"function":"request","class":"GuzzleHttp\\Client","type":"->"},{"file":"/var/www/nextcloud/lib/private/App/AppStore/Fetcher/Fetcher.php","line":120,"function":"get","class":"OC\\Http\\Client\\Client","type":"->"},{"file":"/var/www/nextcloud/lib/private/App/AppStore/Fetcher/AppFetcher.php","line":87,"function":"fetch","class":"OC\\App\\AppStore\\Fetcher\\Fetcher","type":"->"},{"file":"/var/www/nextcloud/lib/private/App/AppStore/Fetcher/Fetcher.php","line":192,"function":"fetch","class":"OC\\App\\AppStore\\Fetcher\\AppFetcher","type":"->"},{"file":"/var/www/nextcloud/lib/private/App/AppStore/Fetcher/AppFetcher.php","line":188,"function":"get","class":"OC\\App\\AppStore\\Fetcher\\Fetcher","type":"->"},{"file":"/var/www/nextcloud/lib/private/Installer.php","line":421,"function":"get","class":"OC\\App\\AppStore\\Fetcher\\AppFetcher","type":"->"},{"file":"/var/www/nextcloud/apps/settings/lib/Controller/AppSettingsController.php","line":151,"function":"isUpdateAvailable","class":"OC\\Installer","type":"->"},{"file":"/var/www/nextcloud/apps/settings/lib/Controller/AppSettingsController.php","line":134,"function":"getAppsWithUpdates","class":"OCA\\Settings\\Controller\\AppSettingsController","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","line":225,"function":"viewApps","class":"OCA\\Settings\\Controller\\AppSettingsController","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","line":133,"function":"executeController","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/App.php","line":172,"function":"dispatch","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/var/www/nextcloud/lib/private/Route/Router.php","line":298,"function":"main","class":"OC\\AppFramework\\App","type":"::"},{"file":"/var/www/nextcloud/lib/base.php","line":1047,"function":"match","class":"OC\\Route\\Router","type":"->"},{"file":"/var/www/nextcloud/index.php","line":36,"function":"handleRequest","class":"OC","type":"::"}],"File":"/var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/Handler/CurlFactory.php","Line":211,"message":"cURL error 23: Failure writing output to destination (see https://curl.haxx.se/libcurl/c/libcurl-errors.html) for https://apps.nextcloud.com/api/v1/apps.json","exception":{},"CustomMessage":"cURL error 23: Failure writing output to destination (see https://curl.haxx.se/libcurl/c/libcurl-errors.html) for https://apps.nextcloud.com/api/v1/apps.json"}}
{"reqId":"ZDaGzEBU82BuUFWLqqZQhQAAWBg","level":3,"time":"2023-04-12T10:24:13+00:00","remoteAddr":"192.168.xxx.xx","user":"xxx","app":"PHP","method":"GET","url":"/index.php/settings/apps/list","message":"fwrite(): Unable to create temporary file, Check permissions in temporary files directory. at /var/www/nextcloud/3rdparty/guzzlehttp/psr7/src/Stream.php#254","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:109.0) Gecko/20100101 Firefox/112.0","version":"25.0.5.1","exception":{"Exception":"Error","Message":"fwrite(): Unable to create temporary file, Check permissions in temporary files directory. at /var/www/nextcloud/3rdparty/guzzlehttp/psr7/src/Stream.php#254","Code":0,"Trace":[{"function":"onError","class":"OC\\Log\\ErrorHandler","type":"::"},{"file":"/var/www/nextcloud/3rdparty/guzzlehttp/psr7/src/Stream.php","line":254,"function":"fwrite"},{"file":"/var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/Handler/CurlFactory.php","line":412,"function":"write","class":"GuzzleHttp\\Psr7\\Stream","type":"->"},{"function":"GuzzleHttp\\Handler\\{closure}","class":"GuzzleHttp\\Handler\\CurlFactory","type":"::","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/Handler/CurlHandler.php","line":44,"function":"curl_exec"},{"file":"/var/www/nextcloud/lib/private/Http/Client/DnsPinMiddleware.php","line":146,"function":"__invoke","class":"GuzzleHttp\\Handler\\CurlHandler","type":"->"},{"file":"/var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/PrepareBodyMiddleware.php","line":35,"function":"OC\\Http\\Client\\{closure}","class":"OC\\Http\\Client\\DnsPinMiddleware","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/Middleware.php","line":31,"function":"__invoke","class":"GuzzleHttp\\PrepareBodyMiddleware","type":"->"},{"file":"/var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/RedirectMiddleware.php","line":71,"function":"GuzzleHttp\\{closure}","class":"GuzzleHttp\\Middleware","type":"::","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/Middleware.php","line":63,"function":"__invoke","class":"GuzzleHttp\\RedirectMiddleware","type":"->"},{"file":"/var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/HandlerStack.php","line":75,"function":"GuzzleHttp\\{closure}","class":"GuzzleHttp\\Middleware","type":"::","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/Client.php","line":331,"function":"__invoke","class":"GuzzleHttp\\HandlerStack","type":"->"},{"file":"/var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/Client.php","line":168,"function":"transfer","class":"GuzzleHttp\\Client","type":"->"},{"file":"/var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/Client.php","line":187,"function":"requestAsync","class":"GuzzleHttp\\Client","type":"->"},{"file":"/var/www/nextcloud/lib/private/Http/Client/Client.php","line":218,"function":"request","class":"GuzzleHttp\\Client","type":"->"},{"file":"/var/www/nextcloud/lib/private/App/AppStore/Fetcher/Fetcher.php","line":120,"function":"get","class":"OC\\Http\\Client\\Client","type":"->"},{"file":"/var/www/nextcloud/lib/private/App/AppStore/Fetcher/AppFetcher.php","line":87,"function":"fetch","class":"OC\\App\\AppStore\\Fetcher\\Fetcher","type":"->"},{"file":"/var/www/nextcloud/lib/private/App/AppStore/Fetcher/Fetcher.php","line":192,"function":"fetch","class":"OC\\App\\AppStore\\Fetcher\\AppFetcher","type":"->"},{"file":"/var/www/nextcloud/lib/private/App/AppStore/Fetcher/AppFetcher.php","line":188,"function":"get","class":"OC\\App\\AppStore\\Fetcher\\Fetcher","type":"->"},{"file":"/var/www/nextcloud/apps/settings/lib/Controller/AppSettingsController.php","line":311,"function":"get","class":"OC\\App\\AppStore\\Fetcher\\AppFetcher","type":"->"},{"file":"/var/www/nextcloud/apps/settings/lib/Controller/AppSettingsController.php","line":205,"function":"getAppsForCategory","class":"OCA\\Settings\\Controller\\AppSettingsController","type":"->"},{"file":"/var/www/nextcloud/apps/settings/lib/Controller/AppSettingsController.php","line":245,"function":"fetchApps","class":"OCA\\Settings\\Controller\\AppSettingsController","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","line":225,"function":"listApps","class":"OCA\\Settings\\Controller\\AppSettingsController","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","line":133,"function":"executeController","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/App.php","line":172,"function":"dispatch","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/var/www/nextcloud/lib/private/Route/Router.php","line":298,"function":"main","class":"OC\\AppFramework\\App","type":"::"},{"file":"/var/www/nextcloud/lib/base.php","line":1047,"function":"match","class":"OC\\Route\\Router","type":"->"},{"file":"/var/www/nextcloud/index.php","line":36,"function":"handleRequest","class":"OC","type":"::"}],"File":"/var/www/nextcloud/lib/private/Log/ErrorHandler.php","Line":92,"CustomMessage":"--"}}
{"reqId":"ZDaGzEBU82BuUFWLqqZQhQAAWBg","level":2,"time":"2023-04-12T10:24:13+00:00","remoteAddr":"192.168.xxx.xx","user":"xxx","app":"appstoreFetcher","method":"GET","url":"/index.php/settings/apps/list","message":"cURL error 23: Failure writing output to destination (see https://curl.haxx.se/libcurl/c/libcurl-errors.html) for https://apps.nextcloud.com/api/v1/apps.json","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:109.0) Gecko/20100101 Firefox/112.0","version":"25.0.5.1","exception":{"Exception":"GuzzleHttp\\Exception\\RequestException","Message":"cURL error 23: Failure writing output to destination (see https://curl.haxx.se/libcurl/c/libcurl-errors.html) for https://apps.nextcloud.com/api/v1/apps.json","Code":200,"Trace":[{"file":"/var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/Handler/CurlFactory.php","line":158,"function":"createRejection","class":"GuzzleHttp\\Handler\\CurlFactory","type":"::"},{"file":"/var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/Handler/CurlFactory.php","line":110,"function":"finishError","class":"GuzzleHttp\\Handler\\CurlFactory","type":"::"},{"file":"/var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/Handler/CurlHandler.php","line":47,"function":"finish","class":"GuzzleHttp\\Handler\\CurlFactory","type":"::"},{"file":"/var/www/nextcloud/lib/private/Http/Client/DnsPinMiddleware.php","line":146,"function":"__invoke","class":"GuzzleHttp\\Handler\\CurlHandler","type":"->"},{"file":"/var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/PrepareBodyMiddleware.php","line":35,"function":"OC\\Http\\Client\\{closure}","class":"OC\\Http\\Client\\DnsPinMiddleware","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/Middleware.php","line":31,"function":"__invoke","class":"GuzzleHttp\\PrepareBodyMiddleware","type":"->"},{"file":"/var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/RedirectMiddleware.php","line":71,"function":"GuzzleHttp\\{closure}","class":"GuzzleHttp\\Middleware","type":"::","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/Middleware.php","line":63,"function":"__invoke","class":"GuzzleHttp\\RedirectMiddleware","type":"->"},{"file":"/var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/HandlerStack.php","line":75,"function":"GuzzleHttp\\{closure}","class":"GuzzleHttp\\Middleware","type":"::","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/Client.php","line":331,"function":"__invoke","class":"GuzzleHttp\\HandlerStack","type":"->"},{"file":"/var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/Client.php","line":168,"function":"transfer","class":"GuzzleHttp\\Client","type":"->"},{"file":"/var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/Client.php","line":187,"function":"requestAsync","class":"GuzzleHttp\\Client","type":"->"},{"file":"/var/www/nextcloud/lib/private/Http/Client/Client.php","line":218,"function":"request","class":"GuzzleHttp\\Client","type":"->"},{"file":"/var/www/nextcloud/lib/private/App/AppStore/Fetcher/Fetcher.php","line":120,"function":"get","class":"OC\\Http\\Client\\Client","type":"->"},{"file":"/var/www/nextcloud/lib/private/App/AppStore/Fetcher/AppFetcher.php","line":87,"function":"fetch","class":"OC\\App\\AppStore\\Fetcher\\Fetcher","type":"->"},{"file":"/var/www/nextcloud/lib/private/App/AppStore/Fetcher/Fetcher.php","line":192,"function":"fetch","class":"OC\\App\\AppStore\\Fetcher\\AppFetcher","type":"->"},{"file":"/var/www/nextcloud/lib/private/App/AppStore/Fetcher/AppFetcher.php","line":188,"function":"get","class":"OC\\App\\AppStore\\Fetcher\\Fetcher","type":"->"},{"file":"/var/www/nextcloud/apps/settings/lib/Controller/AppSettingsController.php","line":311,"function":"get","class":"OC\\App\\AppStore\\Fetcher\\AppFetcher","type":"->"},{"file":"/var/www/nextcloud/apps/settings/lib/Controller/AppSettingsController.php","line":205,"function":"getAppsForCategory","class":"OCA\\Settings\\Controller\\AppSettingsController","type":"->"},{"file":"/var/www/nextcloud/apps/settings/lib/Controller/AppSettingsController.php","line":245,"function":"fetchApps","class":"OCA\\Settings\\Controller\\AppSettingsController","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","line":225,"function":"listApps","class":"OCA\\Settings\\Controller\\AppSettingsController","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","line":133,"function":"executeController","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/App.php","line":172,"function":"dispatch","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/var/www/nextcloud/lib/private/Route/Router.php","line":298,"function":"main","class":"OC\\AppFramework\\App","type":"::"},{"file":"/var/www/nextcloud/lib/base.php","line":1047,"function":"match","class":"OC\\Route\\Router","type":"->"},{"file":"/var/www/nextcloud/index.php","line":36,"function":"handleRequest","class":"OC","type":"::"}],"File":"/var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/Handler/CurlFactory.php","Line":211,"message":"cURL error 23: Failure writing output to destination (see https://curl.haxx.se/libcurl/c/libcurl-errors.html) for https://apps.nextcloud.com/api/v1/apps.json","exception":{},"CustomMessage":"cURL error 23: Failure writing output to destination (see https://curl.haxx.se/libcurl/c/libcurl-errors.html) for https://apps.nextcloud.com/api/v1/apps.json"}}
{"reqId":"ZDaGzEBU82BuUFWLqqZQhQAAWBg","level":3,"time":"2023-04-12T10:24:13+00:00","remoteAddr":"192.168.xxx.xx","user":"xxx","app":"PHP","method":"GET","url":"/index.php/settings/apps/list","message":"fwrite(): Unable to create temporary file, Check permissions in temporary files directory. at /var/www/nextcloud/3rdparty/guzzlehttp/psr7/src/Stream.php#254","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:109.0) Gecko/20100101 Firefox/112.0","version":"25.0.5.1","exception":{"Exception":"Error","Message":"fwrite(): Unable to create temporary file, Check permissions in temporary files directory. at /var/www/nextcloud/3rdparty/guzzlehttp/psr7/src/Stream.php#254","Code":0,"Trace":[{"function":"onError","class":"OC\\Log\\ErrorHandler","type":"::"},{"file":"/var/www/nextcloud/3rdparty/guzzlehttp/psr7/src/Stream.php","line":254,"function":"fwrite"},{"file":"/var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/Handler/CurlFactory.php","line":412,"function":"write","class":"GuzzleHttp\\Psr7\\Stream","type":"->"},{"function":"GuzzleHttp\\Handler\\{closure}","class":"GuzzleHttp\\Handler\\CurlFactory","type":"::","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/Handler/CurlHandler.php","line":44,"function":"curl_exec"},{"file":"/var/www/nextcloud/lib/private/Http/Client/DnsPinMiddleware.php","line":146,"function":"__invoke","class":"GuzzleHttp\\Handler\\CurlHandler","type":"->"},{"file":"/var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/PrepareBodyMiddleware.php","line":35,"function":"OC\\Http\\Client\\{closure}","class":"OC\\Http\\Client\\DnsPinMiddleware","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/Middleware.php","line":31,"function":"__invoke","class":"GuzzleHttp\\PrepareBodyMiddleware","type":"->"},{"file":"/var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/RedirectMiddleware.php","line":71,"function":"GuzzleHttp\\{closure}","class":"GuzzleHttp\\Middleware","type":"::","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/Middleware.php","line":63,"function":"__invoke","class":"GuzzleHttp\\RedirectMiddleware","type":"->"},{"file":"/var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/HandlerStack.php","line":75,"function":"GuzzleHttp\\{closure}","class":"GuzzleHttp\\Middleware","type":"::","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/Client.php","line":331,"function":"__invoke","class":"GuzzleHttp\\HandlerStack","type":"->"},{"file":"/var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/Client.php","line":168,"function":"transfer","class":"GuzzleHttp\\Client","type":"->"},{"file":"/var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/Client.php","line":187,"function":"requestAsync","class":"GuzzleHttp\\Client","type":"->"},{"file":"/var/www/nextcloud/lib/private/Http/Client/Client.php","line":218,"function":"request","class":"GuzzleHttp\\Client","type":"->"},{"file":"/var/www/nextcloud/lib/private/App/AppStore/Fetcher/Fetcher.php","line":120,"function":"get","class":"OC\\Http\\Client\\Client","type":"->"},{"file":"/var/www/nextcloud/lib/private/App/AppStore/Fetcher/AppFetcher.php","line":87,"function":"fetch","class":"OC\\App\\AppStore\\Fetcher\\Fetcher","type":"->"},{"file":"/var/www/nextcloud/lib/private/App/AppStore/Fetcher/Fetcher.php","line":192,"function":"fetch","class":"OC\\App\\AppStore\\Fetcher\\AppFetcher","type":"->"},{"file":"/var/www/nextcloud/lib/private/App/AppStore/Fetcher/AppFetcher.php","line":188,"function":"get","class":"OC\\App\\AppStore\\Fetcher\\Fetcher","type":"->"},{"file":"/var/www/nextcloud/lib/private/Installer.php","line":421,"function":"get","class":"OC\\App\\AppStore\\Fetcher\\AppFetcher","type":"->"},{"file":"/var/www/nextcloud/apps/settings/lib/Controller/AppSettingsController.php","line":259,"function":"isUpdateAvailable","class":"OC\\Installer","type":"->"},{"function":"OCA\\Settings\\Controller\\{closure}","class":"OCA\\Settings\\Controller\\AppSettingsController","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/apps/settings/lib/Controller/AppSettingsController.php","line":251,"function":"array_map"},{"file":"/var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","line":225,"function":"listApps","class":"OCA\\Settings\\Controller\\AppSettingsController","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","line":133,"function":"executeController","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/App.php","line":172,"function":"dispatch","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/var/www/nextcloud/lib/private/Route/Router.php","line":298,"function":"main","class":"OC\\AppFramework\\App","type":"::"},{"file":"/var/www/nextcloud/lib/base.php","line":1047,"function":"match","class":"OC\\Route\\Router","type":"->"},{"file":"/var/www/nextcloud/index.php","line":36,"function":"handleRequest","class":"OC","type":"::"}],"File":"/var/www/nextcloud/lib/private/Log/ErrorHandler.php","Line":92,"CustomMessage":"--"}}
{"reqId":"ZDaGzEBU82BuUFWLqqZQhQAAWBg","level":2,"time":"2023-04-12T10:24:13+00:00","remoteAddr":"192.168.xxx.xx","user":"xxx","app":"appstoreFetcher","method":"GET","url":"/index.php/settings/apps/list","message":"cURL error 23: Failure writing output to destination (see https://curl.haxx.se/libcurl/c/libcurl-errors.html) for https://apps.nextcloud.com/api/v1/apps.json","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:109.0) Gecko/20100101 Firefox/112.0","version":"25.0.5.1","exception":{"Exception":"GuzzleHttp\\Exception\\RequestException","Message":"cURL error 23: Failure writing output to destination (see https://curl.haxx.se/libcurl/c/libcurl-errors.html) for https://apps.nextcloud.com/api/v1/apps.json","Code":200,"Trace":[{"file":"/var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/Handler/CurlFactory.php","line":158,"function":"createRejection","class":"GuzzleHttp\\Handler\\CurlFactory","type":"::"},{"file":"/var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/Handler/CurlFactory.php","line":110,"function":"finishError","class":"GuzzleHttp\\Handler\\CurlFactory","type":"::"},{"file":"/var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/Handler/CurlHandler.php","line":47,"function":"finish","class":"GuzzleHttp\\Handler\\CurlFactory","type":"::"},{"file":"/var/www/nextcloud/lib/private/Http/Client/DnsPinMiddleware.php","line":146,"function":"__invoke","class":"GuzzleHttp\\Handler\\CurlHandler","type":"->"},{"file":"/var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/PrepareBodyMiddleware.php","line":35,"function":"OC\\Http\\Client\\{closure}","class":"OC\\Http\\Client\\DnsPinMiddleware","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/Middleware.php","line":31,"function":"__invoke","class":"GuzzleHttp\\PrepareBodyMiddleware","type":"->"},{"file":"/var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/RedirectMiddleware.php","line":71,"function":"GuzzleHttp\\{closure}","class":"GuzzleHttp\\Middleware","type":"::","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/Middleware.php","line":63,"function":"__invoke","class":"GuzzleHttp\\RedirectMiddleware","type":"->"},{"file":"/var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/HandlerStack.php","line":75,"function":"GuzzleHttp\\{closure}","class":"GuzzleHttp\\Middleware","type":"::","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/Client.php","line":331,"function":"__invoke","class":"GuzzleHttp\\HandlerStack","type":"->"},{"file":"/var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/Client.php","line":168,"function":"transfer","class":"GuzzleHttp\\Client","type":"->"},{"file":"/var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/Client.php","line":187,"function":"requestAsync","class":"GuzzleHttp\\Client","type":"->"},{"file":"/var/www/nextcloud/lib/private/Http/Client/Client.php","line":218,"function":"request","class":"GuzzleHttp\\Client","type":"->"},{"file":"/var/www/nextcloud/lib/private/App/AppStore/Fetcher/Fetcher.php","line":120,"function":"get","class":"OC\\Http\\Client\\Client","type":"->"},{"file":"/var/www/nextcloud/lib/private/App/AppStore/Fetcher/AppFetcher.php","line":87,"function":"fetch","class":"OC\\App\\AppStore\\Fetcher\\Fetcher","type":"->"},{"file":"/var/www/nextcloud/lib/private/App/AppStore/Fetcher/Fetcher.php","line":192,"function":"fetch","class":"OC\\App\\AppStore\\Fetcher\\AppFetcher","type":"->"},{"file":"/var/www/nextcloud/lib/private/App/AppStore/Fetcher/AppFetcher.php","line":188,"function":"get","class":"OC\\App\\AppStore\\Fetcher\\Fetcher","type":"->"},{"file":"/var/www/nextcloud/lib/private/Installer.php","line":421,"function":"get","class":"OC\\App\\AppStore\\Fetcher\\AppFetcher","type":"->"},{"file":"/var/www/nextcloud/apps/settings/lib/Controller/AppSettingsController.php","line":259,"function":"isUpdateAvailable","class":"OC\\Installer","type":"->"},{"function":"OCA\\Settings\\Controller\\{closure}","class":"OCA\\Settings\\Controller\\AppSettingsController","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/apps/settings/lib/Controller/AppSettingsController.php","line":251,"function":"array_map"},{"file":"/var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","line":225,"function":"listApps","class":"OCA\\Settings\\Controller\\AppSettingsController","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","line":133,"function":"executeController","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/App.php","line":172,"function":"dispatch","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/var/www/nextcloud/lib/private/Route/Router.php","line":298,"function":"main","class":"OC\\AppFramework\\App","type":"::"},{"file":"/var/www/nextcloud/lib/base.php","line":1047,"function":"match","class":"OC\\Route\\Router","type":"->"},{"file":"/var/www/nextcloud/index.php","line":36,"function":"handleRequest","class":"OC","type":"::"}],"File":"/var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/Handler/CurlFactory.php","Line":211,"message":"cURL error 23: Failure writing output to destination (see https://curl.haxx.se/libcurl/c/libcurl-errors.html) for https://apps.nextcloud.com/api/v1/apps.json","exception":{},"CustomMessage":"cURL error 23: Failure writing output to destination (see https://curl.haxx.se/libcurl/c/libcurl-errors.html) for https://apps.nextcloud.com/api/v1/apps.json"}}
{"reqId":"ZDaHlEBU82BuUFWLqqZQugAARhU","level":2,"time":"2023-04-12T10:27:57+00:00","remoteAddr":"188.174.53.129","user":"--","app":"core","method":"GET","url":"/index.php/apps/notify_push/uid","message":"Login failed: 'xxx' (Remote IP: '188.174.53.129')","userAgent":"--","version":"25.0.5.1","data":{"app":"core"}}
{"reqId":"ZDaIG0BU82BuUFWLqqZQvwAATRI","level":2,"time":"2023-04-12T10:30:12+00:00","remoteAddr":"188.174.53.129","user":"--","app":"core","method":"GET","url":"/index.php/apps/notify_push/uid","message":"Login failed: 'xxx' (Remote IP: '188.174.53.129')","userAgent":"--","version":"25.0.5.1","data":{"app":"core"}}
{"reqId":"ZDaIots8zrbWeJ9MvPReKQAAkR8","level":2,"time":"2023-04-12T10:32:27+00:00","remoteAddr":"188.174.53.129","user":"--","app":"core","method":"GET","url":"/index.php/apps/notify_push/uid","message":"Login failed: 'xxx' (Remote IP: '188.174.53.129')","userAgent":"--","version":"25.0.5.1","data":{"app":"core"}}
{"reqId":"ZDaJKUBU82BuUFWLqqZQxgAARgA","level":2,"time":"2023-04-12T10:34:42+00:00","remoteAddr":"188.174.53.129","user":"--","app":"core","method":"GET","url":"/index.php/apps/notify_push/uid","message":"Login failed: 'xxx' (Remote IP: '188.174.53.129')","userAgent":"--","version":"25.0.5.1","data":{"app":"core"}}
{"reqId":"ZDaimUBU82BuUFWLqqZS_AAASAY","level":3,"time":"2023-04-12T12:22:49+00:00","remoteAddr":"188.174.53.129","user":"xxx","app":"PHP","method":"PUT","url":"/remote.php/webdav/Auris%20-%20Nach%20einer%20Idee%20von%20Sebastian%20Fitzek.epub","message":"fread(): file created in the system's temporary directory at /var/www/nextcloud/3rdparty/icewind/streams/src/Wrapper.php#55","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:109.0) Gecko/20100101 Firefox/112.0","version":"25.0.5.1","exception":{"Exception":"Error","Message":"fread(): file created in the system's temporary directory at /var/www/nextcloud/3rdparty/icewind/streams/src/Wrapper.php#55","Code":0,"Trace":[{"function":"onError","class":"OC\\Log\\ErrorHandler","type":"::"},{"file":"/var/www/nextcloud/3rdparty/icewind/streams/src/Wrapper.php","line":55,"function":"fread"},{"file":"/var/www/nextcloud/3rdparty/icewind/streams/src/CallbackWrapper.php","line":96,"function":"stream_read","class":"Icewind\\Streams\\Wrapper","type":"->"},{"function":"stream_read","class":"Icewind\\Streams\\CallbackWrapper","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Storage/Local.php","line":312,"function":"file_put_contents"},{"file":"/var/www/nextcloud/lib/private/Files/Storage/Local.php","line":621,"function":"file_put_contents","class":"OC\\Files\\Storage\\Local","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Storage/Wrapper/Wrapper.php","line":647,"function":"writeStream","class":"OC\\Files\\Storage\\Local","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Storage/Wrapper/Wrapper.php","line":647,"function":"writeStream","class":"OC\\Files\\Storage\\Wrapper\\Wrapper","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/Connector/Sabre/File.php","line":248,"function":"writeStream","class":"OC\\Files\\Storage\\Wrapper\\Wrapper","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/Connector/Sabre/Directory.php","line":151,"function":"put","class":"OCA\\DAV\\Connector\\Sabre\\File","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":1098,"function":"createFile","class":"OCA\\DAV\\Connector\\Sabre\\Directory","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php","line":504,"function":"createFile","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"httpPut","class":"Sabre\\DAV\\CorePlugin","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":472,"function":"emit","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":253,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":321,"function":"start","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/apps/dav/appinfo/v1/webdav.php","line":85,"function":"exec","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/remote.php","line":171,"args":["/var/www/nextcloud/apps/dav/appinfo/v1/webdav.php"],"function":"require_once"}],"File":"/var/www/nextcloud/lib/private/Log/ErrorHandler.php","Line":92,"CustomMessage":"--"}}
{"reqId":"ZDaimUBU82BuUFWLqqZS_AAASAY","level":3,"time":"2023-04-12T12:22:49+00:00","remoteAddr":"188.174.53.129","user":"xxx","app":"PHP","method":"PUT","url":"/remote.php/webdav/Auris%20-%20Nach%20einer%20Idee%20von%20Sebastian%20Fitzek.epub","message":"fread(): Unable to create temporary file, Check permissions in temporary files directory. at /var/www/nextcloud/3rdparty/icewind/streams/src/Wrapper.php#55","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:109.0) Gecko/20100101 Firefox/112.0","version":"25.0.5.1","exception":{"Exception":"Error","Message":"fread(): Unable to create temporary file, Check permissions in temporary files directory. at /var/www/nextcloud/3rdparty/icewind/streams/src/Wrapper.php#55","Code":0,"Trace":[{"function":"onError","class":"OC\\Log\\ErrorHandler","type":"::"},{"file":"/var/www/nextcloud/3rdparty/icewind/streams/src/Wrapper.php","line":55,"function":"fread"},{"file":"/var/www/nextcloud/3rdparty/icewind/streams/src/CallbackWrapper.php","line":96,"function":"stream_read","class":"Icewind\\Streams\\Wrapper","type":"->"},{"function":"stream_read","class":"Icewind\\Streams\\CallbackWrapper","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Storage/Local.php","line":312,"function":"file_put_contents"},{"file":"/var/www/nextcloud/lib/private/Files/Storage/Local.php","line":621,"function":"file_put_contents","class":"OC\\Files\\Storage\\Local","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Storage/Wrapper/Wrapper.php","line":647,"function":"writeStream","class":"OC\\Files\\Storage\\Local","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Storage/Wrapper/Wrapper.php","line":647,"function":"writeStream","class":"OC\\Files\\Storage\\Wrapper\\Wrapper","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/Connector/Sabre/File.php","line":248,"function":"writeStream","class":"OC\\Files\\Storage\\Wrapper\\Wrapper","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/Connector/Sabre/Directory.php","line":151,"function":"put","class":"OCA\\DAV\\Connector\\Sabre\\File","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":1098,"function":"createFile","class":"OCA\\DAV\\Connector\\Sabre\\Directory","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php","line":504,"function":"createFile","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"httpPut","class":"Sabre\\DAV\\CorePlugin","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":472,"function":"emit","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":253,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":321,"function":"start","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/apps/dav/appinfo/v1/webdav.php","line":85,"function":"exec","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/remote.php","line":171,"args":["/var/www/nextcloud/apps/dav/appinfo/v1/webdav.php"],"function":"require_once"}],"File":"/var/www/nextcloud/lib/private/Log/ErrorHandler.php","Line":92,"CustomMessage":"--"}}
{"reqId":"ZDaimUBU82BuUFWLqqZS_AAASAY","level":3,"time":"2023-04-12T12:22:49+00:00","remoteAddr":"188.174.53.129","user":"xxx","app":"no app in context","method":"PUT","url":"/remote.php/webdav/Auris%20-%20Nach%20einer%20Idee%20von%20Sebastian%20Fitzek.epub","message":"Erwartete Dateigr\u00f6\u00dfe von 393614 bytes, aber 8192 bytes gelesen (vom Nextcloud-Client) und geschrieben (in den Nextcloud-Speicher). Dies kann entweder ein Netzwerkproblem auf der sendenden Seite oder ein Problem beim Schreiben in den Speicher auf der Serverseite sein.","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:109.0) Gecko/20100101 Firefox/112.0","version":"25.0.5.1","exception":{"Exception":"Sabre\\DAV\\Exception\\BadRequest","Message":"Erwartete Dateigr\u00f6\u00dfe von 393614 bytes, aber 8192 bytes gelesen (vom Nextcloud-Client) und geschrieben (in den Nextcloud-Speicher). Dies kann entweder ein Netzwerkproblem auf der sendenden Seite oder ein Problem beim Schreiben in den Speicher auf der Serverseite sein.","Code":0,"Trace":[{"file":"/var/www/nextcloud/apps/dav/lib/Connector/Sabre/Directory.php","line":151,"function":"put","class":"OCA\\DAV\\Connector\\Sabre\\File","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":1098,"function":"createFile","class":"OCA\\DAV\\Connector\\Sabre\\Directory","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php","line":504,"function":"createFile","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"httpPut","class":"Sabre\\DAV\\CorePlugin","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":472,"function":"emit","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":253,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":321,"function":"start","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/apps/dav/appinfo/v1/webdav.php","line":85,"function":"exec","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/remote.php","line":171,"args":["/var/www/nextcloud/apps/dav/appinfo/v1/webdav.php"],"function":"require_once"}],"File":"/var/www/nextcloud/apps/dav/lib/Connector/Sabre/File.php","Line":297,"message":"Erwartete Dateigr\u00f6\u00dfe von 393614 bytes, aber 8192 bytes gelesen (vom Nextcloud-Client) und geschrieben (in den Nextcloud-Speicher). Dies kann entweder ein Netzwerkproblem auf der sendenden Seite oder ein Problem beim Schreiben in den Speicher auf der Serverseite sein.","exception":{},"CustomMessage":"Erwartete Dateigr\u00f6\u00dfe von 393614 bytes, aber 8192 bytes gelesen (vom Nextcloud-Client) und geschrieben (in den Nextcloud-Speicher). Dies kann entweder ein Netzwerkproblem auf der sendenden Seite oder ein Problem beim Schreiben in den Speicher auf der Serverseite sein."}}
{"reqId":"ZDait0BU82BuUFWLqqZTAgAARAI","level":3,"time":"2023-04-12T12:23:19+00:00","remoteAddr":"188.174.53.129","user":"xxx","app":"PHP","method":"PUT","url":"/remote.php/webdav/Arno%20Strobel%20-%20Fake%20-%20Wer%20soll%20dir%20jetzt%20noch%20glauben.epub","message":"fread(): file created in the system's temporary directory at /var/www/nextcloud/3rdparty/icewind/streams/src/Wrapper.php#55","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:109.0) Gecko/20100101 Firefox/112.0","version":"25.0.5.1","exception":{"Exception":"Error","Message":"fread(): file created in the system's temporary directory at /var/www/nextcloud/3rdparty/icewind/streams/src/Wrapper.php#55","Code":0,"Trace":[{"function":"onError","class":"OC\\Log\\ErrorHandler","type":"::"},{"file":"/var/www/nextcloud/3rdparty/icewind/streams/src/Wrapper.php","line":55,"function":"fread"},{"file":"/var/www/nextcloud/3rdparty/icewind/streams/src/CallbackWrapper.php","line":96,"function":"stream_read","class":"Icewind\\Streams\\Wrapper","type":"->"},{"function":"stream_read","class":"Icewind\\Streams\\CallbackWrapper","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Storage/Local.php","line":312,"function":"file_put_contents"},{"file":"/var/www/nextcloud/lib/private/Files/Storage/Local.php","line":621,"function":"file_put_contents","class":"OC\\Files\\Storage\\Local","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Storage/Wrapper/Wrapper.php","line":647,"function":"writeStream","class":"OC\\Files\\Storage\\Local","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Storage/Wrapper/Wrapper.php","line":647,"function":"writeStream","class":"OC\\Files\\Storage\\Wrapper\\Wrapper","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/Connector/Sabre/File.php","line":248,"function":"writeStream","class":"OC\\Files\\Storage\\Wrapper\\Wrapper","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/Connector/Sabre/Directory.php","line":151,"function":"put","class":"OCA\\DAV\\Connector\\Sabre\\File","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":1098,"function":"createFile","class":"OCA\\DAV\\Connector\\Sabre\\Directory","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php","line":504,"function":"createFile","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"httpPut","class":"Sabre\\DAV\\CorePlugin","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":472,"function":"emit","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":253,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":321,"function":"start","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/apps/dav/appinfo/v1/webdav.php","line":85,"function":"exec","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/remote.php","line":171,"args":["/var/www/nextcloud/apps/dav/appinfo/v1/webdav.php"],"function":"require_once"}],"File":"/var/www/nextcloud/lib/private/Log/ErrorHandler.php","Line":92,"CustomMessage":"--"}}
{"reqId":"ZDait0BU82BuUFWLqqZTAgAARAI","level":3,"time":"2023-04-12T12:23:19+00:00","remoteAddr":"188.174.53.129","user":"xxx","app":"PHP","method":"PUT","url":"/remote.php/webdav/Arno%20Strobel%20-%20Fake%20-%20Wer%20soll%20dir%20jetzt%20noch%20glauben.epub","message":"fread(): Unable to create temporary file, Check permissions in temporary files directory. at /var/www/nextcloud/3rdparty/icewind/streams/src/Wrapper.php#55","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:109.0) Gecko/20100101 Firefox/112.0","version":"25.0.5.1","exception":{"Exception":"Error","Message":"fread(): Unable to create temporary file, Check permissions in temporary files directory. at /var/www/nextcloud/3rdparty/icewind/streams/src/Wrapper.php#55","Code":0,"Trace":[{"function":"onError","class":"OC\\Log\\ErrorHandler","type":"::"},{"file":"/var/www/nextcloud/3rdparty/icewind/streams/src/Wrapper.php","line":55,"function":"fread"},{"file":"/var/www/nextcloud/3rdparty/icewind/streams/src/CallbackWrapper.php","line":96,"function":"stream_read","class":"Icewind\\Streams\\Wrapper","type":"->"},{"function":"stream_read","class":"Icewind\\Streams\\CallbackWrapper","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Storage/Local.php","line":312,"function":"file_put_contents"},{"file":"/var/www/nextcloud/lib/private/Files/Storage/Local.php","line":621,"function":"file_put_contents","class":"OC\\Files\\Storage\\Local","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Storage/Wrapper/Wrapper.php","line":647,"function":"writeStream","class":"OC\\Files\\Storage\\Local","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Storage/Wrapper/Wrapper.php","line":647,"function":"writeStream","class":"OC\\Files\\Storage\\Wrapper\\Wrapper","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/Connector/Sabre/File.php","line":248,"function":"writeStream","class":"OC\\Files\\Storage\\Wrapper\\Wrapper","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/Connector/Sabre/Directory.php","line":151,"function":"put","class":"OCA\\DAV\\Connector\\Sabre\\File","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":1098,"function":"createFile","class":"OCA\\DAV\\Connector\\Sabre\\Directory","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php","line":504,"function":"createFile","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"httpPut","class":"Sabre\\DAV\\CorePlugin","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":472,"function":"emit","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":253,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":321,"function":"start","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/apps/dav/appinfo/v1/webdav.php","line":85,"function":"exec","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/remote.php","line":171,"args":["/var/www/nextcloud/apps/dav/appinfo/v1/webdav.php"],"function":"require_once"}],"File":"/var/www/nextcloud/lib/private/Log/ErrorHandler.php","Line":92,"CustomMessage":"--"}}
{"reqId":"ZDait0BU82BuUFWLqqZTAgAARAI","level":3,"time":"2023-04-12T12:23:19+00:00","remoteAddr":"188.174.53.129","user":"xxx","app":"no app in context","method":"PUT","url":"/remote.php/webdav/Arno%20Strobel%20-%20Fake%20-%20Wer%20soll%20dir%20jetzt%20noch%20glauben.epub","message":"Erwartete Dateigr\u00f6\u00dfe von 1609672 bytes, aber 8192 bytes gelesen (vom Nextcloud-Client) und geschrieben (in den Nextcloud-Speicher). Dies kann entweder ein Netzwerkproblem auf der sendenden Seite oder ein Problem beim Schreiben in den Speicher auf der Serverseite sein.","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:109.0) Gecko/20100101 Firefox/112.0","version":"25.0.5.1","exception":{"Exception":"Sabre\\DAV\\Exception\\BadRequest","Message":"Erwartete Dateigr\u00f6\u00dfe von 1609672 bytes, aber 8192 bytes gelesen (vom Nextcloud-Client) und geschrieben (in den Nextcloud-Speicher). Dies kann entweder ein Netzwerkproblem auf der sendenden Seite oder ein Problem beim Schreiben in den Speicher auf der Serverseite sein.","Code":0,"Trace":[{"file":"/var/www/nextcloud/apps/dav/lib/Connector/Sabre/Directory.php","line":151,"function":"put","class":"OCA\\DAV\\Connector\\Sabre\\File","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":1098,"function":"createFile","class":"OCA\\DAV\\Connector\\Sabre\\Directory","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php","line":504,"function":"createFile","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"httpPut","class":"Sabre\\DAV\\CorePlugin","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":472,"function":"emit","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":253,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":321,"function":"start","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/apps/dav/appinfo/v1/webdav.php","line":85,"function":"exec","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/remote.php","line":171,"args":["/var/www/nextcloud/apps/dav/appinfo/v1/webdav.php"],"function":"require_once"}],"File":"/var/www/nextcloud/apps/dav/lib/Connector/Sabre/File.php","Line":297,"message":"Erwartete Dateigr\u00f6\u00dfe von 1609672 bytes, aber 8192 bytes gelesen (vom Nextcloud-Client) und geschrieben (in den Nextcloud-Speicher). Dies kann entweder ein Netzwerkproblem auf der sendenden Seite oder ein Problem beim Schreiben in den Speicher auf der Serverseite sein.","exception":{},"CustomMessage":"Erwartete Dateigr\u00f6\u00dfe von 1609672 bytes, aber 8192 bytes gelesen (vom Nextcloud-Client) und geschrieben (in den Nextcloud-Speicher). Dies kann entweder ein Netzwerkproblem auf der sendenden Seite oder ein Problem beim Schreiben in den Speicher auf der Serverseite sein."}}
{"reqId":"kZ7XtTOtEX81RzaAOVjc","level":4,"time":"2023-04-12T12:48:05+00:00","remoteAddr":"","user":"--","app":"no app in context","method":"","url":"--","message":"Could not boot workflowengine: An exception occurred while executing a query: SQLSTATE[70100]: <<Unknown error>>: 1927 Connection was killed","userAgent":"--","version":"25.0.5.1","exception":{"Exception":"Doctrine\\DBAL\\Exception\\DriverException","Message":"An exception occurred while executing a query: SQLSTATE[70100]: <<Unknown error>>: 1927 Connection was killed","Code":1927,"Trace":[{"file":"/var/www/nextcloud/3rdparty/doctrine/dbal/src/Connection.php","line":1780,"function":"convert","class":"Doctrine\\DBAL\\Driver\\API\\MySQL\\ExceptionConverter","type":"->"},{"file":"/var/www/nextcloud/3rdparty/doctrine/dbal/src/Connection.php","line":1719,"function":"handleDriverException","class":"Doctrine\\DBAL\\Connection","type":"->"},{"file":"/var/www/nextcloud/3rdparty/doctrine/dbal/src/Connection.php","line":1067,"function":"convertExceptionDuringQuery","class":"Doctrine\\DBAL\\Connection","type":"->"},{"file":"/var/www/nextcloud/lib/private/DB/Connection.php","line":261,"function":"executeQuery","class":"Doctrine\\DBAL\\Connection","type":"->"},{"file":"/var/www/nextcloud/3rdparty/doctrine/dbal/src/Query/QueryBuilder.php","line":345,"function":"executeQuery","class":"OC\\DB\\Connection","type":"->"},{"file":"/var/www/nextcloud/lib/private/DB/QueryBuilder/QueryBuilder.php","line":281,"function":"execute","class":"Doctrine\\DBAL\\Query\\QueryBuilder","type":"->"},{"file":"/var/www/nextcloud/apps/workflowengine/lib/Manager.php","line":164,"function":"execute","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->"},{"file":"/var/www/nextcloud/apps/workflowengine/lib/AppInfo/Application.php","line":75,"function":"getAllConfiguredEvents","class":"OCA\\WorkflowEngine\\Manager","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/Bootstrap/FunctionInjector.php","line":67,"function":"registerRuleListeners","class":"OCA\\WorkflowEngine\\AppInfo\\Application","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/Bootstrap/BootContext.php","line":51,"function":"injectFn","class":"OC\\AppFramework\\Bootstrap\\FunctionInjector","type":"->"},{"file":"/var/www/nextcloud/apps/workflowengine/lib/AppInfo/Application.php","line":67,"function":"injectFn","class":"OC\\AppFramework\\Bootstrap\\BootContext","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/Bootstrap/Coordinator.php","line":190,"function":"boot","class":"OCA\\WorkflowEngine\\AppInfo\\Application","type":"->"},{"file":"/var/www/nextcloud/lib/private/legacy/OC_App.php","line":208,"function":"bootApp","class":"OC\\AppFramework\\Bootstrap\\Coordinator","type":"->"},{"file":"/var/www/nextcloud/lib/private/legacy/OC_App.php","line":141,"function":"loadApp","class":"OC_App","type":"::"},{"file":"/var/www/nextcloud/lib/private/Console/Application.php","line":120,"function":"loadApps","class":"OC_App","type":"::"},{"file":"/var/www/nextcloud/console.php","line":99,"function":"loadCommands","class":"OC\\Console\\Application","type":"->"},{"file":"/var/www/nextcloud/occ","line":11,"args":["/var/www/nextcloud/console.php"],"function":"require_once"}],"File":"/var/www/nextcloud/3rdparty/doctrine/dbal/src/Driver/API/MySQL/ExceptionConverter.php","Line":114,"Previous":{"Exception":"Doctrine\\DBAL\\Driver\\PDO\\Exception","Message":"SQLSTATE[70100]: <<Unknown error>>: 1927 Connection was killed","Code":1927,"Trace":[{"file":"/var/www/nextcloud/3rdparty/doctrine/dbal/src/Driver/PDO/Statement.php","line":94,"function":"new","class":"Doctrine\\DBAL\\Driver\\PDO\\Exception","type":"::"},{"file":"/var/www/nextcloud/3rdparty/doctrine/dbal/src/Connection.php","line":1057,"function":"execute","class":"Doctrine\\DBAL\\Driver\\PDO\\Statement","type":"->"},{"file":"/var/www/nextcloud/lib/private/DB/Connection.php","line":261,"function":"executeQuery","class":"Doctrine\\DBAL\\Connection","type":"->"},{"file":"/var/www/nextcloud/3rdparty/doctrine/dbal/src/Query/QueryBuilder.php","line":345,"function":"executeQuery","class":"OC\\DB\\Connection","type":"->"},{"file":"/var/www/nextcloud/lib/private/DB/QueryBuilder/QueryBuilder.php","line":281,"function":"execute","class":"Doctrine\\DBAL\\Query\\QueryBuilder","type":"->"},{"file":"/var/www/nextcloud/apps/workflowengine/lib/Manager.php","line":164,"function":"execute","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->"},{"file":"/var/www/nextcloud/apps/workflowengine/lib/AppInfo/Application.php","line":75,"function":"getAllConfiguredEvents","class":"OCA\\WorkflowEngine\\Manager","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/Bootstrap/FunctionInjector.php","line":67,"function":"registerRuleListeners","class":"OCA\\WorkflowEngine\\AppInfo\\Application","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/Bootstrap/BootContext.php","line":51,"function":"injectFn","class":"OC\\AppFramework\\Bootstrap\\FunctionInjector","type":"->"},{"file":"/var/www/nextcloud/apps/workflowengine/lib/AppInfo/Application.php","line":67,"function":"injectFn","class":"OC\\AppFramework\\Bootstrap\\BootContext","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/Bootstrap/Coordinator.php","line":190,"function":"boot","class":"OCA\\WorkflowEngine\\AppInfo\\Application","type":"->"},{"file":"/var/www/nextcloud/lib/private/legacy/OC_App.php","line":208,"function":"bootApp","class":"OC\\AppFramework\\Bootstrap\\Coordinator","type":"->"},{"file":"/var/www/nextcloud/lib/private/legacy/OC_App.php","line":141,"function":"loadApp","class":"OC_App","type":"::"},{"file":"/var/www/nextcloud/lib/private/Console/Application.php","line":120,"function":"loadApps","class":"OC_App","type":"::"},{"file":"/var/www/nextcloud/console.php","line":99,"function":"loadCommands","class":"OC\\Console\\Application","type":"->"},{"file":"/var/www/nextcloud/occ","line":11,"args":["/var/www/nextcloud/console.php"],"function":"require_once"}],"File":"/var/www/nextcloud/3rdparty/doctrine/dbal/src/Driver/PDO/Exception.php","Line":26,"Previous":{"Exception":"PDOException","Message":"SQLSTATE[70100]: <<Unknown error>>: 1927 Connection was killed","Code":"70100","Trace":[{"file":"/var/www/nextcloud/3rdparty/doctrine/dbal/src/Driver/PDO/Statement.php","line":92,"function":"execute","class":"PDOStatement","type":"->"},{"file":"/var/www/nextcloud/3rdparty/doctrine/dbal/src/Connection.php","line":1057,"function":"execute","class":"Doctrine\\DBAL\\Driver\\PDO\\Statement","type":"->"},{"file":"/var/www/nextcloud/lib/private/DB/Connection.php","line":261,"function":"executeQuery","class":"Doctrine\\DBAL\\Connection","type":"->"},{"file":"/var/www/nextcloud/3rdparty/doctrine/dbal/src/Query/QueryBuilder.php","line":345,"function":"executeQuery","class":"OC\\DB\\Connection","type":"->"},{"file":"/var/www/nextcloud/lib/private/DB/QueryBuilder/QueryBuilder.php","line":281,"function":"execute","class":"Doctrine\\DBAL\\Query\\QueryBuilder","type":"->"},{"file":"/var/www/nextcloud/apps/workflowengine/lib/Manager.php","line":164,"function":"execute","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->"},{"file":"/var/www/nextcloud/apps/workflowengine/lib/AppInfo/Application.php","line":75,"function":"getAllConfiguredEvents","class":"OCA\\WorkflowEngine\\Manager","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/Bootstrap/FunctionInjector.php","line":67,"function":"registerRuleListeners","class":"OCA\\WorkflowEngine\\AppInfo\\Application","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/Bootstrap/BootContext.php","line":51,"function":"injectFn","class":"OC\\AppFramework\\Bootstrap\\FunctionInjector","type":"->"},{"file":"/var/www/nextcloud/apps/workflowengine/lib/AppInfo/Application.php","line":67,"function":"injectFn","class":"OC\\AppFramework\\Bootstrap\\BootContext","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/Bootstrap/Coordinator.php","line":190,"function":"boot","class":"OCA\\WorkflowEngine\\AppInfo\\Application","type":"->"},{"file":"/var/www/nextcloud/lib/private/legacy/OC_App.php","line":208,"function":"bootApp","class":"OC\\AppFramework\\Bootstrap\\Coordinator","type":"->"},{"file":"/var/www/nextcloud/lib/private/legacy/OC_App.php","line":141,"function":"loadApp","class":"OC_App","type":"::"},{"file":"/var/www/nextcloud/lib/private/Console/Application.php","line":120,"function":"loadApps","class":"OC_App","type":"::"},{"file":"/var/www/nextcloud/console.php","line":99,"function":"loadCommands","class":"OC\\Console\\Application","type":"->"},{"file":"/var/www/nextcloud/occ","line":11,"args":["/var/www/nextcloud/console.php"],"function":"require_once"}],"File":"/var/www/nextcloud/3rdparty/doctrine/dbal/src/Driver/PDO/Statement.php","Line":92}},"message":"Could not boot workflowengine: An exception occurred while executing a query: SQLSTATE[70100]: <<Unknown error>>: 1927 Connection was killed","exception":{},"CustomMessage":"Could not boot workflowengine: An exception occurred while executing a query: SQLSTATE[70100]: <<Unknown error>>: 1927 Connection was killed"}}
{"reqId":"ZDba-IC3F2r4ZVBLBr_9GAAAThM","level":2,"time":"2023-04-12T16:23:47+00:00","remoteAddr":"188.174.53.129","user":"--","app":"no app in context","method":"POST","url":"/login","message":"Login failed: xxx (Remote IP: 188.174.53.129)","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:109.0) Gecko/20100101 Firefox/112.0","version":"25.0.5.1","data":[]}
{"reqId":"ZDbbNKphiELYq488UD2y3wAACgk","level":2,"time":"2023-04-12T16:24:46+00:00","remoteAddr":"188.174.53.129","user":"--","app":"no app in context","method":"POST","url":"/login","message":"Login failed: xxx (Remote IP: 188.174.53.129)","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:109.0) Gecko/20100101 Firefox/112.0","version":"25.0.5.1","data":[]}
