If you’re urgently looking for support to keep your business running, consider checking out our paid support options.
example
longer
example
here
Remember, the below information may be requested if it isn’t supplied; for fastest response please provide as much as you can
Please delete everything above when creating your topic, just provide the following:
Nextcloud version (eg, 12.0.2): 12.0.4
Operating system and version (eg, Ubuntu 17.04): Ubuntu 16.04
Apache or nginx version (eg, Apache 2.4.25): nginx
PHP version (eg, 7.1): 7.0
When accessing the web-interface the browser shows “Internal Server Error”. WebDAV/NC-Clients seems to be working.
After my first attempt to migrate to a new server and upgrade from NC11 to NC12 the login-button of web-interface were not working. Since I was not able to find a solution I started from beginnen (my working NC11 Setup on the other machine), did the migration and upgrade as instructed in the manual.
{"reqId":"GOhG6TLzQTP0wjcv64ek","level":3,"time":"2018-01-07T08:40:28+00:00","remoteAddr":"84.161.146.153","user":"admin","app":"core","method":"GET","url":"\/apps\/files\/","message":"Exception: {\"Exception\":\"OCP\\\\Files\\\\NotFoundException\",\"Message\":\"\",\"Code\":0,\"Trace\":\"#0 \\\/var\\\/www\\\/nextcloud\\\/lib\\\/private\\\/Files\\\/Node\\\/Node.php(217): OC\\\\Files\\\\Node\\\\Node->getFileInfo()\\n#1 \\\/var\\\/www\\\/nextcloud\\\/lib\\\/private\\\/Files\\\/Node\\\/Node.php(117): OC\\\\Files\\\\Node\\\\Node->getPermissions()\\n#2 \\\/var\\\/www\\\/nextcloud\\\/lib\\\/private\\\/Files\\\/Node\\\/File.php(62): OC\\\\Files\\\\Node\\\\Node->checkPermissions(2)\\n#3 \\\/var\\\/www\\\/nextcloud\\\/lib\\\/private\\\/Files\\\/SimpleFS\\\/SimpleFile.php(95): OC\\\\Files\\\\Node\\\\File->putContent('html,body,div,s...')\\n#4 \\\/var\\\/www\\\/nextcloud\\\/lib\\\/private\\\/Template\\\/SCSSCacher.php(230): OC\\\\Files\\\\SimpleFS\\\\SimpleFile->putContent('html,body,div,s...')\\n#5 \\\/var\\\/www\\\/nextcloud\\\/lib\\\/private\\\/Template\\\/SCSSCacher.php(112): OC\\\\Template\\\\SCSSCacher->cache('\\\/var\\\/www\\\/nextcl...', '03b4383e0499f9d...', 'server.scss', Object(OC\\\\Files\\\\SimpleFS\\\\SimpleFolder), 'core\\\/css')\\n#6 \\\/var\\\/www\\\/nextcloud\\\/lib\\\/private\\\/Template\\\/CSSResourceLocator.php(105): OC\\\\Template\\\\SCSSCacher->process('\\\/var\\\/www\\\/nextcl...', 'core\\\/css\\\/server...', 'core')\\n#7 \\\/var\\\/www\\\/nextcloud\\\/lib\\\/private\\\/Template\\\/CSSResourceLocator.php(57): OC\\\\Template\\\\CSSResourceLocator->cacheAndAppendScssIfExist('\\\/var\\\/www\\\/nextcl...', 'core\\\/css\\\/server...')\\n#8 \\\/var\\\/www\\\/nextcloud\\\/lib\\\/private\\\/Template\\\/ResourceLocator.php(76): OC\\\\Template\\\\CSSResourceLocator->doFind('css\\\/server')\\n#9 \\\/var\\\/www\\\/nextcloud\\\/lib\\\/private\\\/TemplateLayout.php(225): OC\\\\Template\\\\ResourceLocator->find(Array)\\n#10 \\\/var\\\/www\\\/nextcloud\\\/lib\\\/private\\\/TemplateLayout.php(170): OC\\\\TemplateLayout::findStylesheetFiles(Array)\\n#11 \\\/var\\\/www\\\/nextcloud\\\/lib\\\/private\\\/legacy\\\/template.php(205): OC\\\\TemplateLayout->__construct('error', '')\\n#12 \\\/var\\\/www\\\/nextcloud\\\/lib\\\/private\\\/Template\\\/Base.php(132): OC_Template->fetchPage()\\n#13 \\\/var\\\/www\\\/nextcloud\\\/lib\\\/private\\\/legacy\\\/template.php(342): OC\\\\Template\\\\Base->printPage()\\n#14 \\\/var\\\/www\\\/nextcloud\\\/index.php(67): OC_Template::printExceptionErrorPage(Object(OCP\\\\Files\\\\NotFoundException))\\n#15 {main}\",\"File\":\"\\\/var\\\/www\\\/nextcloud\\\/lib\\\/private\\\/Files\\\/Node\\\/Node.php\",\"Line\":97}","userAgent":"Mozilla\/5.0 (Macintosh; Intel Mac OS X 10_13_2) AppleWebKit\/604.4.7 (KHTML, like Gecko) Version\/11.0.2 Safari\/604.4.7","version":"12.0.4.3"}
'instanceid' => 'occ65uljh4d0',
'passwordsalt' => 'OBMjcmeiWylxkinif6YCswLlElBnuj',
'secret' => 'VkXZ1yq5v6OICK7sCmBF0Nhu8XX3ST6gJTPRw8JuB6Y+LErd',
0 => 'serverhostname',
1 => 'mydomain.de',
2 => 'dyndns.myfritz.net',
3 => '127.0.0.1',
4 => '192.168.1.120',
5 => 'www.mydomain.de',
'datadirectory' => '/srv/md0/nextcloud/data',
'overwrite.cli.url' => 'https://mydomain.de',
'version' => '12.0.4.3',
'dbname' => 'nextcloudDB',
'dbhost' => 'localhost',
'dbuser' => 'DBUser',
'dbpassword' => 'DBPassword',
'logtimezone' => 'UTC',
'theme' => '',
'loglevel' => 0,
'auth.bruteforce.protection.enabled' => false,
'data-fingerprint' => 'a368d5b8d20171a463beaaff88046104',
PHP message: {"reqId":"2tn7DVLdRhptu7FvZvHz","level":3,"time":"2018-01-07T07:53:29+00:00","remoteAddr":"84.161.146.153","user":"--","app":"PHP","method":"GET","url":"\/status.php","message":"chmod(): Permission denied at \/var\/www\/nextcloud\/lib\/private\/Log\/File.php#134","userAgent":"Mozilla\/5.0 (Windows) mirall\/2.4.0 (build 8894)","version":"12.0.4.3"}" while reading upstream, client: 127.0.0.1, server: 127.0.0.1, request: "GET /status.php HTTP/1.0", upstream: "fastcgi://unix:/run/php/php7.0-fpm.sock:", host: "mydomain.de"
I verified the file from the nginx-log is owned by www-data and has read/write rights.
