WebDAV does not lock MS Office files
Nextcloud version (eg, 20.0.5): 27.1.5
Operating system and version (eg, Ubuntu 20.04): Debian GNU/Linux 11 (bullseye)
Apache or nginx version (eg, Apache 2.4.25): Apache 2
PHP version (eg, 7.4): PHP 8.2.14
User A creates a New document file.xlsx works in it, User B logs into it and starts working too.
As a result, user A does not save the changes.
Both work through a WebDAV drive, not through an application.
How can I prevent users from opening the same file via WebDAV?
Install and use the Temporary files lock app :wink:
Thanks for the answer, but there is one question.
Does it extend to Webdav and block Word files on webdav if you try to open it?
To be honest I cannot answer that question because my envioronment is to small to run into file editing collisions, but from the description I would assume that it is exactly what you’re looking for.
I checked again, it turns out I misunderstood you. “Temporary files lock” helped me solve this problem, thanks for the hint.
